installing an old version of Linuxcnc
13 Jan 2013 20:19 - 13 Jan 2013 22:54 #28648 by delta
Hey,
I have installed the 2.5.1
is it possible to install an older version
apt-get install linuxcnc=2.5.0 doesnt work ??
Thank u
Last edit: 13 Jan 2013 22:54 by delta.
13 Jan 2013 20:53 #28650 by ArcEye
Replied by ArcEye on topic installing an old version of Linuxcnc
Hi
You will have to explain. There is no version 2.51, the latest version is 2.5.1, which it appears you have installed.
Yet you appear to be trying to install the same version, despite saying you want an earlier one? :blink:
13 Jan 2013 22:55 #28653 by delta
Replied by delta on topic installing an old version of Linuxcnc
Sorry,
for example i have version 2.5.1
and now i want to install 2.5.0
how is that possible
13 Jan 2013 23:54 #28654 by ArcEye
Hi
It is the same as any other package
Go into Synaptic package manager, input 'linuxcnc' in the search box.
It will then show you all the matching packages with that string in their names.
Select the 'linuxcnc' package and it will show installed version as 2.5.1
Do Ctrl-E to select Force Version and select 2.5.0 from the drop down and confirm.
Then click on Apply and 2.5.1 will be removed and 2.5.0 installed.
The big question is WHY?
Time to create page: 0.063 seconds
