O103 repeat ... O103 endrepeat question
- FRD
21 Jan 2013 07:12 #28894
by FRD
O103 repeat ... O103 endrepeat question was created by FRD
Please hellp me to understand what is going on and how to fix it.
I am running EMC2/AXIS 2.4.6. When I try to use O103 repeat ... O103 endrepeat more than once in the same program I get the following error:
Near line 21 of /home/fred/projects/test.txt:
Radius to end of arc differs from radius to start:
start=(X0.0000,Y-10.0000)
center=(X0.0000,Y20.0000)
end=(X0.0000,Y-30.0000) r1=30.0000 r2=50.0000
The line is question is "G3 X0.0000 Y-30.0000 I0.0000 J30.0000" below.
The purpose of the program is to mill two circles into a piece of wood a little bit at a time.
The program is:
(test.txt)
(tool 1, 12.7 dia. 1/2 end mill)
G17 G21 G40 G49 G54 G80 G90 G94
F400
G1 x0.0000 y-50.0000 z10.0000
G42 D1
G1 X0.0000 Y-30.0000
#<zval> = 0.0000
O103 repeat [10]
#<zval> = [#<zval> - 0.01000]
G1 z#<zval>
O103 endrepeat
G1 Z2.0000
G1 X0.0000 Y-10.0000
#<zval> = 0.0000
O103 repeat [10]
G1 z#<zval>
G3 X0.0000 Y-10.0000 I0.0000 J10.0000
O103 endrepeat
G1 Z10.0000
G40
G1 Y50.0000
Thanks.
Fred
The program is:
(test.txt)
F400
G42 D1
#<zval> = 0.0000
O103 repeat [10]
G1 z#<zval>
O103 endrepeat
G1 Z2.0000
#<zval> = 0.0000
O103 repeat [10]
G1 z#<zval>
O103 endrepeat
G1 Z10.0000
G40
G1 Y50.0000
Thanks.
Fred
- BigJohnT
- Thank you received: 1176
21 Jan 2013 20:18 #28916
by BigJohnT
Replied by BigJohnT on topic O103 repeat ... O103 endrepeat question
The error is an arc error. Also you need to use unique numbers for each o loop.
If you want to make 10 circles just us the P word with the arc along with the final Z depth.
linuxcnc.org/docs/html/gcode/gcode.html#...a_id_sec_g2_g3_arc_a
- FRD
23 Jan 2013 07:53 #28995
by FRD
Replied by FRD on topic O103 repeat ... O103 endrepeat question
Thanks very much for your help.
I thought that "O103" was the command for "repeat ... end repeat" like the g-codes which are made up of a "G" and a number. Now I realize that the "103" part of the command is a subroutine identifier. I changed the identifier for the other "repeat ... end repeat" loop and the program works.
The arc error must have been related to the conflict caused by using the same subroutine identifier for both loops.
Thanks again.
Fred
Thanks again.
Fred
Time to create page: 0.045 seconds
