QUESTION SERVOMOTOR
- jlviloria
- Thank you received: 12
23 Jan 2013 10:19 #29000
by jlviloria
QUESTION SERVOMOTOR was created by jlviloria
Greetings friends ...
I was watching a servomotor dmm-tech.com, I want to know if anyone has worked with these actuators, if support linuxcnc and mesanet.
thank you very much in advance for your attention
Jorge Viloria
Jorge Viloria
- cncbasher
- Thank you received: 288
23 Jan 2013 16:03 #29008
by cncbasher
Replied by cncbasher on topic QUESTION SERVOMOTOR
so long as you use their servo drives which support Pulse/Direction or CW/CCW, and Analog communication modes
then they will work with Linuxcnc and mesanet with approprate addon interface makes it easier etc .
most modern servo drives support pulse / direction connectivity so no major difference in connections than a step /directon , this is mostly Industry standard
modern servo drives have an encoder quadrature output , which is then linked into Linuxcnc for closed loop .
- Thank you received: 4970
23 Jan 2013 17:42 #29011
I don't know if anyone has actually used them yet, but I have talked to DMM-Tech and they believe that the DYN3-H drive is LinuxCNC compatible. (In fact they were quite keen to have "LinuxCNC certification" and seemed a little bit disappointed when I had to admit we were too chaotic to have such a scheme)
The DYN3-H drive has a choice of pulse or analogue input, but more importantly for LinuxCNC it outputs quadrature encoder pulses. (The actual encoder on the motors is magnetic)
This means that you can run the DYN3-H drive either from an analogue output board (for example the 7i77) or from the step/dir board (eg 7i76). My preference would be for the analogue-voltage control, at least partly because the 7i77 has encoder counters.
The other drives are less convenient for LinuxCNC, they are pulse-control only and don't have a usable feedback to LinuxCNC.
Replied by andypugh on topic QUESTION SERVOMOTOR
- jlviloria
23 Jan 2013 22:26 - 23 Jan 2013 22:46 #29027
by jlviloria
Replied by jlviloria on topic QUESTION SERVOMOTOR
Thanks for your answers.
it is to know I'm not the expert on this topic.
I have a kit 5i25 and 7i77.
I want to buy specifically
DYN3-T
Applicable Servo Motor Capacity: 1.5kW - 2.0kW
32M-DHT-28
2.0kW AC Servo motor
Rated 2000rpm, Rated torque: 9.5Nm, Peak torque: 28.0Nm
31M-DHT-15
1.5kW AC servo motor
Rated 3000rpm, Rated torque: 5.0Nm, Peak torque: 15.0Nm
another could use another brand, that is not so expensive, these specifications?
thanks
Jorge Viloria
DYN3-T
32M-DHT-28
31M-DHT-15
thanks
Jorge Viloria
Last edit: 23 Jan 2013 22:46 by jlviloria.
- jlviloria
24 Jan 2013 20:47 #29078
by jlviloria
good afternoon,
taking into account the characteristics of servomotors I need, which is a good option cost / benefit and integrate with linuxcnc and 7i77?
I think it is a good topic to discuss,
You can make a list of the best and well linuxcnc servomotors to guide novices like me.
I make the list.
In advance thank you very much for your attention
I make the list.
- BigJohnT
- Thank you received: 1176
24 Jan 2013 20:52 #29080
by BigJohnT
Replied by BigJohnT on topic QUESTION SERVOMOTOR
There was some discussion a while back on the users mailing list you might search for them.
Time to create page: 0.059 seconds
