Servo Motors with TTL Differential, Incremental...
25 Jan 2013 23:42 #29141 by Piscis
Lately is getting harder to find a Servo Motors with TTL Differential, Incremental encoder. Does anyone in this forum knows any suppliers that might have this type of motors?
I already have the servo drives with me, now I need to purchase the servo motors compatible with it. These are the specifications. Any help will be highly appreciated.
AC Brushless Servo Drive
Lenze Americas: Model "PositionServo" #E94P040Y2NEM
Continuous Current | Drive Rating in Amps = 4 Amps
Peak Current 12 Amps
Actual input voltage range: 80VAC to 264VAC, 1Ø
Number of Pole = Eight (8)
MOTOR FEEDBACK | ENCODER:
TTL Differential, Incremental encoder with Hall emulation tracks or Hall sensors necessary for commutation with resolution of 2000 PPR or higher
A link to the specs and manual are here:
dl.dropbox.com/u/58111636/PositionServo%...0Hardware%20V2.0.pdf
dl.dropbox.com/u/58111636/Lenze%20Servo%...oduct%20Brochure.pdf
27 Jan 2013 01:12 #29164 by Kirk_Wallace
Replied by Kirk_Wallace on topic Servo Motors with TTL Differential, Incremental...
I tend to make my own encoders and fit them to the ball screw.
www.wallacecompany.com/cnc_lathe/HNC/00001-1a.jpg
www.wallacecompany.com/cnc_lathe/HNC/00011-1a.jpg
www.wallacecompany.com/cnc_lathe/HNC/00004-1a.jpg
The second and third picture show a perf board with a differential chip that is used to convert the TTL signals from the quadrature sensor to RS422 differential. These chips are easy to find and wire up.
www.digikey.com/product-search/en/integr...vers/2556324?k=rs422
www.jameco.com/webapp/wcs/stores/servlet...eText=rs-422%20rs422
U S Digital has chips, boards and complete encoders.
www.usdigital.com/products/interfaces/encoder/cable-drivers
en.wikipedia.org/wiki/Differential_signaling
Kirk Wallace
www.wallacecompany.com/machine_shop/
27 Jan 2013 01:19 #29165 by Piscis
Great idea, Thanks a lot!
28 Jan 2013 05:52 #29204 by andypugh
That is only part of the solution here, though, as the drives in question appear to also require Hall commutation signals.
It might be worth keeping an eye on eBay (though the only Lenze servon on there now has a Resolver rather than an encoder)
www.zappautomation.co.uk/en/35-servo-motors
Appear to have incremental encoders and, as far as I can see, UVW Hall sensors too.
28 Jan 2013 20:06 #29222 by Piscis
Kirk - Andy
Do you know by any chance if there is a list within LinuxCNC showing servo motors suppliers with reasonable good price and quality. The reasons I’m using Lenze servo drives is due to the included Ethernet port, Basic language programming, Modbus TCP communications and the $450.00 USD price.
I have not been able to find a similar proposal anywhere else. I use servo drives mostly in standalone applications and now I’m planning to used them with LinuxCNC.
Thanks for the knowledge.
29 Jan 2013 02:20 #29232 by Kirk_Wallace
I would shy away from smart controller/drivers for LinuxCNC which has motion control logic built in. There are plenty of people using these kinds of controllers, but it seems that either the controller or LinuxCNC need to be compromised to get it to work. Usually the controller's PID needs to be tuned and sorted out separately, then LinuxCNC's PID needs to be tuned or reconfigured to live with the controller. LinuxCNC integrates better with dumb drivers or amplifiers that use simple velocity or torque commands, with all of the tuning going on and openly available in LinuxCNC. Mesa and Pico Systems have FPGA interfaces and amplifiers that work well with LinuxCNC and motors with common encoders and Hall sensors. Keling www.kelinginc.net/DCBrushlessMotor.html seems to get mentioned for motors.
Kirk
Time to create page: 0.213 seconds
