XYUV Foamcuttter configuration from scratch-- HELP
- erick.szekely
31 Jan 2013 07:09 #29343
by erick.szekely
XYUV Foamcuttter configuration from scratch-- HELP was created by erick.szekely
i have been fiddling and finagling for months on trying to get a xyuv foamcutter set up. i have all the hardware the software is where im stuck. i want instructions in ENGLISH on how to install from scratch in the right directory a version of linux cnc that supports and will display both ends of the wire and the wire strung between.
Please no spamming and no bumping lets keep this a clean post for future users so they can use use this as a guide.
- Thank you received: 4917
31 Jan 2013 23:53 #29386
Replied by andypugh on topic XYUV Foamcuttter configuration from scratch-- HELP
I think you might want the specific modifications made by Sammel Lothar.
These are only available in the "master" (Development) branch.
So, first you want to get that. Follow the instructions here:
buildbot.linuxcnc.org/
When it says "put one of these stanzas in your xxx file" it means that you need to create that file and put the stuff in it.
You should then find a new simulated machine in the sample configs of the config picker, sim/axis/axis_foam.
That is probably a good starting point for your configuration.
- Gelar
11 Feb 2013 20:10 #29901
by Gelar
Replied by Gelar on topic XYUV Foamcuttter configuration from scratch-- HELP
do you want to have 4 independent axes or 2 pairs of parallel?
Time to create page: 0.238 seconds
