Can anyone suggest a USB Wireless Card that...
- Piscis
11 Feb 2013 20:45 #29903
by Piscis
Can anyone suggest a USB Wireless Card that... was created by Piscis
Can anyone suggest a USB Wireless Card that is 100% compatible with Ubuntu Linux? OR better yet how can I make my Intel Motherboard BOXD525MW connect wireless to my 75 feet away Router?
- BigJohnT
- Thank you received: 1176
11 Feb 2013 21:51 #29905
by BigJohnT
Replied by BigJohnT on topic Can anyone suggest a USB Wireless Card that...
Best thing I know of is to run some CAT5E over to your router.
I don't recall any happy stories about wireless and Ubuntu...
- ArcEye
- Thank you received: 758
11 Feb 2013 22:43 #29911
by ArcEye
Use a pair of homeplugs between a ringmain socket near your router (not an extension lead) and a socket in your workshop, and then connect with ethernet
Mine work 200ft from the house.
Don't bother with wireless, it does not like motors, metal and concrete or long distances.
Replied by ArcEye on topic Can anyone suggest a USB Wireless Card that...
OR better yet how can I make my Intel Motherboard BOXD525MW connect ..............to my 75 feet away Router?
- BigJohnT
11 Feb 2013 22:56 #29913
by BigJohnT
Is that the same as the X10 things for your house?
- ArcEye
11 Feb 2013 23:12 #29916
by ArcEye
- Piscis
11 Feb 2013 23:24 #29918
by Piscis
Replied by Piscis on topic Can anyone suggest a USB Wireless Card that...
That's a great idea, I think I will forget about wireless and buy one of this:
www.seniorgamers.net/home/2012/08/wired-...th-devolo-homeplugs/
- ArcEye
11 Feb 2013 23:53 #29919
by ArcEye
Just do a bit of research on the specs, there are a variety of speeds 85, 100, 200 MBs and some specify range ie the length of cable it will work over.
Mine are just 85MBs Solwise units, much cheaper than Netgear etc but work fine
I have a WiFi Homeplug adaptor in the workshop, which means I can use my smartphone down there (so long as I don't have a machine running)
- BigJohnT
12 Feb 2013 00:29 #29921
by BigJohnT
Yep, a higher bandwidth version of X10 that came out in the 70's
en.wikipedia.org/wiki/X10_(industry_standard)
It is these, I'm not familiar with X10 but could be
en.wikipedia.org/wiki/HomePlug
- Thank you received: 4967
13 Feb 2013 01:58 #29970
Replied by andypugh on topic Can anyone suggest a USB Wireless Card that...
I am using www.currys.co.uk/gbuk/cisco-linksys-plsk...er-13927476-pdt.html to link two CNC machines and an IP camera in the garage to my home network. And I still have a spare network socket for the future.
It's worth knowing that the multi-port ones exist.
- birchy
18 Feb 2013 07:17 - 18 Feb 2013 07:21 #30236
by birchy
Replied by birchy on topic Can anyone suggest a USB Wireless Card that...
Not sure if you've seen my recent post, but I developed a simple solution that allows me to use a PCI WiFi card but automatically disable the driver if Axis or Latency Test are running...
www.linuxcnc.org/index.php/english/forum...iver-auto-loadunload
EDIT:
The above is only going to be useful if you can get a decent signal with a wifi card. Your best bet would be to try connecting to your router over wifi using a mobile phone, tablet, laptop, netbook, etc from your machine location. If any of those have a weak signal, then wireless is not the way forward...
EDIT:
Last edit: 18 Feb 2013 07:21 by birchy.
Time to create page: 0.075 seconds
