Linuxcnc 2.6 Bugs
16 Mar 2013 04:17 #31473 by REEEN
Linuxcnc 2.6 Bugs was created by REEEN
Hello,
I found a lot of bugs in the 2.6 version og linuxcnc, but I don`t know where to report them.
So here are they:
-Gremlin and Dro do not show velocity if selected
-Very important issue ! Spindle at speed does nothing !
-Remap ngc files do not support feeds
-Remap M115 does not work (unknown Mcode)
I use the newest version of 2.6
The Spindle at speed thing is a very big issue please fix it.
Greets REEEN
16 Mar 2013 05:01 #31474 by skunkworks
16 Mar 2013 08:27 #31484 by andypugh
Replied by andypugh on topic Linuxcnc 2.6 Bugs
Really?
Can you post your HAL file? Just to exclude a configuration fault.
17 Mar 2013 02:45 - 17 Mar 2013 02:50 #31504 by REEEN
Replied by REEEN on topic Linuxcnc 2.6 Bugs
I`ll post it tomorrow but I`m 100 percent sure I checked it with halmeter spindle at speed is false but the programm goes on the Signal becomes true as my spindle reaches its speed but Linuxcnc does not care about spindle at speed.
I also noticed a lot of other bugs today...
-Sometimes the tooltable won`t show up
-G43 does not show in the active Gcodes window, when I type in I only see G49 but G43 works after all
-if I use a grid in Gremlin it does not work
-Setting default max velocity does not work it always uses the max velocity
2.6 is very very buggy ...
But the biggest problem this time is the spindle at speed thing.
For bow I remapped m13 and m14 with
M3 /M4
M109
M109 is a user defined Mcode which waits for spindle at speed signal to become true .
Last edit: 17 Mar 2013 02:50 by REEEN.
17 Mar 2013 03:41 #31505 by andypugh
I just checked it, and it behaves as described in the manual for me.
www.linuxcnc.org/docs/html/man/man9/motion.9.html
It only pauses feed moves, not rapids, and it is only active after a change in spindle speed.
I seem to manage to lose it behind other windows quite often, it isn't this is it?
I don't thing G43 is a modal code, so isn't shown in the list.
There is scope for some confusion here. There are settings with the same name in [TRAJ] and [DISPLAY], and they do slightly different things.
Can you be specific about what setting you are changing? There is no DEFAULT_MAX_VELOCITY setting
www.linuxcnc.org/docs/html/config/ini_co...tml#sub:TRAJ-section
17 Mar 2013 18:24 #31511 by BigJohnT
Replied by BigJohnT on topic Linuxcnc 2.6 Bugs
If I type T1 M6 G43 in the MDI window of 2.5.2 it shows up in both LinuxCNC Status window and the Active G-Codes window.
Time to create page: 0.058 seconds
