X Y axis don' work togheter
- milan
22 Mar 2013 01:54 #31687
by milan
X Y axis don' work togheter was created by milan
Can anyone help me to figure out what's going on.
I've made a stepper machine and running Linuxcnc 2.5 with Ubuntu 10.04
I manage to get the machine working using step configuration but I'problem holding sizes.
Moving X or Y axis on their own the position is correct not so moving both axis.
G2 and G3 result in oval holes.
Changing velocity and acceleration does not make any difference.
I'm pretty sure the machine is not loosing any steps because running the same G code several time it
ends up in the same place.
Running Linuxcnc on a Dell Dimension 4700 pc.
- alan_3301
- Thank you received: 33
22 Mar 2013 03:50 #31692
by alan_3301
Replied by alan_3301 on topic X Y axis don' work togheter
How big are the holes?
How much backlash do you have? I think that is usual cause of ovals.
are you using screws or something else? what kind of screws also.
The following user(s) said Thank You: milan
- milan
22 Mar 2013 04:43 #31694
by milan
Replied by milan on topic X Y axis don' work togheter
Thanks for getting back so quickly.
Ball screw on all axis.The worst axis has a backlash of .o4mm.
The hole diameter is 50mm.The difference measuring across on a 45 is of 1mm.
I'attaching my ini file. may be I messed up there
- alan_3301
22 Mar 2013 05:05 #31695
by alan_3301
Your X scale is different than Y and Z
SCALE = 251.968503937
is that right for X? X and Y are different lead screws? and Y and Z are the same?
- milan
22 Mar 2013 05:32 - 22 Mar 2013 06:02 #31697
by milan
Yes the x screw has a pitch of 6.35mm (1/4 inch.) while the y and z have 5mm pitch.
The X axis has a bigger screw and moves most of the weight.
What puzzles me is that I find difference even when i cut on a angle.
If I cut a square normal to the axis it checks out pretty good, cutting the same square rotated
45 I don't get a square any more.
Last edit: 22 Mar 2013 06:02 by milan. Reason: Spelling
- alan_3301
22 Mar 2013 06:00 #31699
by alan_3301
Hmm. I'm not sure then. your ini looks good to me, but I am still learning.
Maybe your x and y arent perpindicular?
- milan
22 Mar 2013 06:16 #31700
by milan
Hum! that is an idea, it was checked when the machine was assembled, may be something got loose.
I'm going to check tomorrow.
Thanks for the hint.
- Rick G
- Thank you received: 155
22 Mar 2013 18:12 #31720
by Rick G
Replied by Rick G on topic X Y axis don' work togheter
Are you using G61 or G64 P- Q- ?
Are the results the same?
Rick G
Rick G
- cncbasher
- Thank you received: 288
22 Mar 2013 20:06 #31725
by cncbasher
Replied by cncbasher on topic X Y axis don' work togheter
i would be looking at mechanical movement or flex in the gantry as the cutter is biting , etc
try placing a felt tip in the spindle and tracing the path it should be a image of the cut , if it is not then the chances are it's mechanical
- milan
23 Mar 2013 12:01 #31758
by milan
I think Alan_3301 had the answer, to my surprise I found that X is not perpendicular to y; dial indicators don't tell me so.
I'm now fixing it and i will try again when done.
I'll let you know.
Thank very mach to Alan and everyone else that helped.
PS: Sometime you look far when what you'r looking for is under your nose.
I'll let you know.
Time to create page: 0.083 seconds
