lathe tool up
- emad_ahmed2
25 Mar 2013 21:09 #31849
by emad_ahmed2
Replied by emad_ahmed2 on topic lathe tool up
I have 2 MPG(Handwheel) and I need to use one for x and one for z
And i need to change homing sequencing becose I have z homing first and then x
- ArcEye
- Thank you received: 758
25 Mar 2013 23:28 #31860
by ArcEye
Replied by ArcEye on topic lathe tool up
I assume you are asking a question?
You don't need 2 MPGs, just one and a switch to change axes.
linuxcnc.org/docs/2.5/html/config/ini_ho....html#_home_sequence
- Thank you received: 2154
26 Mar 2013 04:22 #31878
Replied by cmorley on topic lathe tool up
If you have spare encoder components on the 7i77 connect your MPGs to them.
then connect in HAL the encoder pins to
axis.N.jog-counts
www.linuxcnc.org/docs/2.5/html/config/emc2hal.html#_axis_joints
There is more to it then that - looking for an example...
As ArcEye said you can use one MPG with a switch or one for each axis if you like.
If I remember right the 7i77 has a mode that adds special low speed encoder counters just for MPGs too.
Chris M
axis.N.jog-counts
Chris M
Time to create page: 0.056 seconds
