spindle speed to control step rate
- ronb
16 May 2013 02:51 #34146
by ronb
spindle speed to control step rate was created by ronb
Hi ,
Is it possible to use spindle speed feed back to control feed rate? I am trying to set up linux cnc to operate a quilting machine.
- Thank you received: 1455
16 May 2013 04:48 #34153
Replied by Todd Zuercher on topic spindle speed to control step rate
yes
The following user(s) said Thank You: ronb
- ronb
16 May 2013 05:19 #34156
by ronb
Replied by ronb on topic spindle speed to control step rate
My thought was to use an index pulse or encoder to monitor machine speed. with a set number of stitches per inch, factor a feed rate set point to maintain stitches per inch. x and y axis will have about 200 steps per inch, a work space of 16 inches by 120 inches. Will get back to the manual.
ron
ron
- Thank you received: 4929
16 May 2013 07:17 #34163
That may be as simple as using G95 feed-per-rev mode.
Or you may need to use adaptive feed.
Replied by andypugh on topic spindle speed to control step rate
ron
Time to create page: 0.054 seconds
