A complete tutorial to control a VFD & Spindle
- laurent_parti
- Thank you received: 11
29 May 2013 14:08 #34896
by laurent_parti
A complete tutorial to control a VFD & Spindle was created by laurent_parti
Hi all,
If this forum would not exist, I would never be able to create my CNC and fix all my concern with.
My biggest problem was about controling a VFD/inverter with linux CNC.
I create a complete tutorial to help other member as I found great support here:
The complete tutorial
- Thank you received: 4976
29 May 2013 19:17 #34908
Replied by andypugh on topic A complete tutorial to control a VFD & Spindle
What was the problem with the first pwm-to-voltage circuit, and was it this one here?
tom-itx.dyndns.org:81/~webpage/cnc/ACPL-P480_opto_sch.png
(Which I can't see through the company firewall, and might not still exist)
- laurent_parti
31 May 2013 16:00 #35006
by laurent_parti
Replied by laurent_parti on topic A complete tutorial to control a VFD & Spindle
Hello andy,
It was not this circuit. The problem was that the huanyang VFD does "answer" to Linux CNC signal.
Then I spent a long times on youtube & forums to find informations about converting a 0-5v pwm signal to a 0-10v huanyang inverter.
One guy explained me that the huanyang electronic does have a very different impedance thant the rest of the circuit and this impedance affect the PWM signal. So he explained me to put an AOP between the BOB and the optical circuit with a simple follower with a gain of one. The effect is to isolate (from impedance side of view) both circuits from to BOB to the huanyang electronic. So I did that (it is very easy) and it works great !
Time to create page: 0.054 seconds
