DLP 3D Printer - Linux CNC customization
- fgcity
06 Jun 2013 15:51 #35318
by fgcity
DLP 3D Printer - Linux CNC customization was created by fgcity
Hi everyone,
I am working on a DLP 3D printer and have already made some nice prints with it. Currently i am using MACH3 and am controlling the machine through the LPT port.
I use a custom Script for MACH to basically move an axis, open up a Power Point file and slide through each projection image while moving the axis again.
I am completely new to LinuxCNC but i want to use it and customize it for the DLP (SLA) 3D printer i have.
The whole process of control is quite simple except for one thing, which is the display of each layer as an image on the screen. The machine only has one axis to control and that is the Z lift platform. so my process is this:
1. Move Z 1mm up
2. Display a PNG image Full Screen
3. Wait 5 seconds
4. Show Black Screen
3. Move Z 1mm up
And this goes on and on for the available amount of PNG layer images.
I wanted to ask some help here, if someone could tell me what exactly i would need to do to make this work on LinuxCNC. Would i need a custom UI or i can do this with a script of sorts on LinuxCNC? I do know some programming but haven't used LinuxCNC before so please forgive me for the dumb questions in advance.
Perhaps there is a project already similar to this that i can look at? Any help would really be appreciated.
1. Move Z 1mm up
3. Wait 5 seconds
3. Move Z 1mm up
- Thank you received: 2160
07 Jun 2013 12:47 #35386
Replied by cmorley on topic DLP 3D Printer - Linux CNC customization
This sounds like a job for just HAL actually.
But you could do this by using linuxcnc and a custom M code to call an external program to show or hide a picture on the screen.
I bet you could use information from this page:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Axis_Embed_Video
Or customise a GUI like Gscreen to do what you want.
Chris M
Chris M
- Thank you received: 4976
07 Jun 2013 21:58 #35412
I think a custom UI would be most satisfactory, but not stricly neccessary.
G-code can be persuaded to display an image, have a look at the two custom M-code examples at the very bottom of this page:
linuxcnc.org/docs/html/gcode/m-code.html
I guess the projector is set up as a separate screen?
I would be more tempted to have a HAL + glade system. A very simple HAL file to load a single stepgen + the realtime system, and a GaldeVCP UI to load / display the image files and drive the stepgen input pin.
So, an executable script to start your system called "dlp"
Then a HAL file called dlp.hal
All off the top of my head, totally untested, but an indication of what is involved.
There is a vaguely similar (non working) complete config here: linuxcnc.org/hardy/dapper/index.php/ital...al-power-laser#22961
Replied by andypugh on topic DLP 3D Printer - Linux CNC customization
1. Move Z 1mm up
3. Wait 5 seconds
I wanted to ask some help here, if someone could tell me what exactly i would need to do to make this work on LinuxCNC. Would i need a custom UI or i can do this with a script of sorts on LinuxCNC?.
#!/bin/bash
halrun -f dlp.hal
loadrt threads name1=base-thread period1=100000 name2=servo-thread period2=1000000
loadrt stepgen count=1
loadrt hal_parport cfg="0x378 out"
addf stepgen.update-freq servo-thread
net step stepgen.0.step => parport.0.pin-09-out
net dir stepgen.0.dir => parport.0.pin-10-out
loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} dlp.py dlp.ui
net pos-cmd dlp.motor-pos-cmd => stepgen.0.position-cmd
start
The following user(s) said Thank You: fgcity
- fgcity
07 Jun 2013 22:03 #35413
by fgcity
Replied by fgcity on topic DLP 3D Printer - Linux CNC customization
Tnx guys, i really appreciate your help on this. Will try out few things as soon as i get the hang of the code for the custom UI.
