Tool length offset problem
06 Jun 2013 16:02 #35319 by aaron
Tool length offset problem was created by aaron
Hi
Can any one tell me how to edit the tool table in linuxcnc so that it does not add tool length offsets to the gcode generated by sheetcam.
Cheers
Aaron
06 Jun 2013 17:43 #35321 by BigJohnT
Replied by BigJohnT on topic Tool length offset problem
Change the length to 0? Sheetcam is usually used with a plasma, what are you doing?
JT
06 Jun 2013 17:58 #35322 by aaron
Replied by aaron on topic Tool length offset problem
I am using a gantry syle router. I have tried editing the tool table but it seems to revert back to a default.
06 Jun 2013 18:06 #35324 by BigJohnT
How are you editing the tool file?
Are you touching off your tool prior to cutting?
JT
06 Jun 2013 19:23 #35338 by aaron
No I'm not touching off.
Can I edit the tooltable through axis?
06 Jun 2013 19:53 #35340 by cncbasher
Replied by cncbasher on topic Tool length offset problem
tool.tbl can be edited using any text editor , are you editing the correct one ?
the tool.tbl file in use is the one in the configuration you are starting linuxcnc in ... i.e ~/linuxcnc/configs/myconfiguration/
06 Jun 2013 20:51 #35343 by BigJohnT
How are you setting the tool length if your not touching off?
Can you describe in some detail what your doing and what you want to happen?
JT
Time to create page: 0.055 seconds
