Using LinuxCNC as a simulator for a Fanuc Lathe,
- scubasteve1
13 Jul 2013 10:52 #36618
by scubasteve1
Using LinuxCNC as a simulator for a Fanuc Lathe, was created by scubasteve1
Hello, I'm new to Linux and LinuxCNC, but am checking on a bit. I've tried looking for info on modifying the linuxcnc control's logic a bit, and changing some G-codes. Can anyone point me in the right direction? I would like to build a profile to simulate my lathe, so I can program, edit, debug, and simulate all in one monitor.
- ArcEye
- Thank you received: 758
13 Jul 2013 17:25 #36620
by ArcEye
Replied by ArcEye on topic Using LinuxCNC as a simulator for a Fanuc Lathe,
Hi
Before you get into this I would look at the G Codes that Linuxcnc uses
linuxcnc.org/docs/2.5/html/gcode/gcode.html
Although it is based on the same standard as fanuc uses, there are some major omissions where a lathe is concerned, G71 and G72 especially.
Linuxcnc also does not use line numbers, so numbered blocks are meaningless to it.
If you use these codes heavily, you will have to write the interpreter code yourself to use them and probably use the G Code remapping facility in the master do do some of it
www.linuxcnc.org/docs/devel/html/remap/structure.html
I get around this by using ngcgui to allow the finished profile to be described and call subroutines to do the decrementing of values down to finished size.
There has been quite a bit of discussion on G71 and G72 recently, search on that and you will see.
- scubasteve1
15 Jul 2013 11:13 #36654
by scubasteve1
Replied by scubasteve1 on topic Using LinuxCNC as a simulator for a Fanuc Lathe,
I'm not worried about using g70 and g71, or usings sequance numbers/numbered lines at all really. For starters I would like to try to mimick the existing controls for Fanuc 0T, as they still work great and I'm not in a position to retro fit the lathes yet. Mostly to see if I miss a decimal or something and I can catch that on the simulator...
It looks like I'll have to brush up on Python some in order to change the control?
- Thank you received: 5018
15 Jul 2013 19:01 #36668
In that mode the current LinuxCNC should just work.
Replied by andypugh on topic Using LinuxCNC as a simulator for a Fanuc Lathe,
