Change axis resolution on the fly?
- tenaja
- Thank you received: 5
21 Jul 2013 23:52 #36867
by tenaja
Change axis resolution on the fly? was created by tenaja
I would like to try changing my axis resolution on the fly...is there a way, without losing positioning?
By switching to full stepping during the Homing process, my homing should be (slightly) more consistent. Since my drive has jumpers to change the resolution, I should be able to toggle them "easily" with an i/o pin. How do I change the steps/inch that linuxcnc uses for distance traveled, on the fly?
This will also come in handy to increase the Rapid speeds, since I am running into pulse rate issues. Is there a way to step to a specific step from "home" so when you toggle to full stepping, your (for instance) 1/16 step is aligned with it?
Or is this idea too much to ask of LinuxCNC?
Thanks...
Thanks...
- Thank you received: 2127
22 Jul 2013 00:38 #36870
Replied by cmorley on topic Change axis resolution on the fly?
Not sure how full stepping will help your homing process but it would increase your speed.
look here - this seems to be what you want to do:
thread.gmane.org/gmane.linux.distributio...er/45102/focus=45279
Linuxcnc is amazingly flexible.
Chris M
Chris M
- tenaja
23 Jul 2013 07:30 - 23 Jul 2013 07:32 #36921
by tenaja
Replied by tenaja on topic Change axis resolution on the fly?
Thanks--that is very good news.
If the home switch is only repeatable within .01mm, and a full step of the motor is .02mm, it will always home on the same step in the same physical location. With 1/16 microstepping on (0.00125mm resolution), the home can vary by 8 steps. That is how lower resolution can improve homing repeatability.
But the resolution switching on the fly should be great for faster rapids, too.
Last edit: 23 Jul 2013 07:32 by tenaja.
23 Jul 2013 07:57 #36922
I should point out that in the example I quoted, that Linuxcnc was driving the individual coils of the stepper.
So the example is not quite the same as you would like.
But I bet the principal could still work.
I bet it depends on what happens in the driver when you switch step resolution on the fly.
Chris M
Chris M
Time to create page: 0.050 seconds
