Four Processes with LinuxCNC
- yutingkao23
23 Jul 2013 23:21 #36947
by yutingkao23
Four Processes with LinuxCNC was created by yutingkao23
Hi, I want to ask a question. When I run LinuxCNC script, the four processes start up. How do they communication with each other ? Use NML or another way ?
Thanks.
Thanks.
- ArcEye
- Thank you received: 758
24 Jul 2013 00:13 - 24 Jul 2013 00:52 #36949
by ArcEye
Replied by ArcEye on topic Four Processes with LinuxCNC
Hi
You will have to elaborate as to which 4 processes you mean
For instance this is ps -A just after linuxcnc is started
27523 pts/1 00:00:00 linuxcnc
27664 pts/1 00:00:00 linuxcncsvr
27681 ? 00:00:00 RTAI_KTHRD_M:0
27682 ? 00:00:00 F:HARD:0:1
27683 ? 00:00:00 RTAI_KTHRD_M:1
27684 ? 00:00:00 RTAI_KTHRD_M:2
27685 ? 00:00:00 F:HARD:1:1
27686 ? 00:00:00 F:HARD:2:1
27687 ? 00:00:00 RTAI_KTHRD_M:3
27688 ? 00:00:00 F:HARD:3:1
27703 ? 00:00:00 udevd
27704 ? 00:00:00 udevd
27710 pts/1 00:00:00 io
27712 pts/1 00:00:00 halui
27727 pts/1 00:00:00 hal_manualtoolc
27737 pts/1 00:00:00 milltask
but yes probably
(EDIT If you search the source for RCS_STAT_CHANNEL you will pick up the various processes and which NML channel they attach to )
but yes probably
Last edit: 24 Jul 2013 00:52 by ArcEye.
Time to create page: 0.057 seconds
