5axiskins &LinuxCnc 2.5.3
- Thank you received: 4970
28 Jul 2013 18:08 #37143
The point of pivot seems to be the W position from the tip of the tool.
So, if you have a 100mm tool and the W position is -100 then the pivot is about the point where the tool enters the head.
If you then G0 W0 then the pivot will be about the tip of the tool.
If you G0 W100 then the pivot will be about a point 100mm away from the tool.
XYZ define a point in space.
AB define the angle the tool makes to that point
W defines the radius at which the tool moves.
Replied by andypugh on topic 5axiskins &LinuxCnc 2.5.3
But when I rotate axis the reference point is still in the top of the head and not on the top of the tool as I expect.
Is it same on your test?
- eslavko
28 Jul 2013 18:45 #37148
by eslavko
Replied by eslavko on topic 5axiskins &LinuxCnc 2.5.3
Hmm after G0W0 thing really does what I expect...
So actualy if I want point to be in the tip of the tool I do need to do G0 W0 after tool change ?!?
I need to do a lot of learning about 5axis machines
28 Jul 2013 19:14 #37150
I think this is normal. Even with a conventional machine.
If you put in a longer tool and do a g43 there isn't any axis movement until you actually ask for it.
G0 Z0 -> head at a particular height
M6 T1 G43 -> head stays at that height
G0 Z0 -> head moves up to allow for longer tool.
You tend to not notice this because a tool change normally coincides with a retract.
- eslavko
28 Jul 2013 19:29 #37155
by eslavko
As I have only my little 3 axis mill, and no toolchange, I did not needed that until now.
I was thinking after XYZ (I already know) I need to learn something about BC axis. But there is actualy UVW seet too to keep track (at least W part of them)
A lot of learning to do....
Time to create page: 0.050 seconds
