rebutting the computer
07 Aug 2013 03:06 #37461 by twscnc2
rebutting the computer was created by twscnc2
is there a way to make a change in wizard
without rebutting the computer to activate the change?
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
07 Aug 2013 05:57 #37465 by andypugh
Replied by andypugh on topic rebutting the computer
Yes, you only need to restart LinuxCNC to see the changes made by the Wizard.
You can also change many things on a live configuration, look at Machine->Calibration. (This is probably only useful for servo configurations).
You can also make many changes by using various commands in the Machine -> Show Hal Configuration window (you have to know the halcmd commands).
You can also do the same thing without the graphical pin list from the command prompt with halcmd. But you rather need to understand HAL to know what you are doing.
11 Aug 2013 04:12 #37547 by twscnc2
Replied by twscnc2 on topic rebutting the computer
i looked for a place to restart Linux only.
can't find it.
can i get more detailed instructions?
thanks
11 Aug 2013 16:24 #37557 by ArcEye
Replied by ArcEye on topic rebutting the computer
Hi
You don't need to re-start linux.
The wizard makes a configuration saved in a sub-directory of /home/yourname/linuxcnc/configs/
If you edit again in the wizard, it saves the alterations and the next time you start linuxcnc it will load the new configuration.
All you need to do is close linuxcnc, make your changes and then open linuxcnc again, choosing the amended config from the config chooser dialog.
The only time you might need to re-start linux, is if you screw up the module loading and unloading, possibly by leaving linuxcnc running and trying to run a latency test
or move the motors through stepconf , maybe not even then.
12 Aug 2013 01:34 #37568 by twscnc2
thanks
i`ll try that
Time to create page: 0.056 seconds
