Formula as HAL parameter
14 Aug 2013 22:01 #37669 by eslavko
Formula as HAL parameter was created by eslavko
Hello...
Is it possible to use formula in HAL parameter?
For example in my HAL is line
setp   hm2_7i43.0.stepgen.02.dirsetup        [AXIS_0]DIRSETUP
and this works OK.
But what about something like
setp   hm2_7i43.0.stepgen.02.maxaccel   [AXIS_0]MAX_ACCELERATION * 1.5
as stepgen acceleration should be 1.5 to 2 times of max acceleration?
14 Aug 2013 22:55 - 14 Aug 2013 22:55 #37672 by ArcEye
Replied by ArcEye on topic Formula as HAL parameter
AFAIK you cannot assign a value based upon the result of a mathmatical operation in a hal file
You don't need to, because if the variable does not exist, you can just create it in your .ini file and assign it by [SECTION]Name
The only ways to use the ini file variables I can think of are
value = [SECTION]Value as in setp device.0.param [SECTION]Value
string = [SECTION](Name) as in loadrt [SECTION](NameToLoad)
I have never seen documentation for this, would be interested if there was some
Last edit: 14 Aug 2013 22:55 by ArcEye.
14 Aug 2013 23:20 #37675 by eslavko
Replied by eslavko on topic Formula as HAL parameter
I just asking as I'd like to avoid cnahging numbers in two files.
acceleration and max speed are that. And (I don't know why) max speed in stepgen must be higher than declared speed for axis. If backlash is used up to two times higher?!?
So when machine is configured and finding optimal values we must align two numbers in different file to be in sync (but not same).
I still don't get why I have max velocity declared in at least 3 places?!?
14 Aug 2013 23:39 #37676 by PCW
Replied by PCW on topic Formula as HAL parameter
The stepgen maxvel (and stepgen maxaccel) must be set higher than the machine
maxvel and maxaccel since the stepgen must have headroom (the +25% or so)
to be able to do corrections when at the maximum machine velocity or acceleration
Time to create page: 0.063 seconds
