Jog with encoder and key.
23 Aug 2013 15:17 #37986 by eslavko
Jog with encoder and key. was created by eslavko
Hello...
I have homemade pendant with encoder wheel. It works nice. But the machine is large and I don't like to spend all time to travel from one side to the other to rotate that knob. But I had key available to do jog with max speed, but cant find solution where I should connect it in hal.
So in short. For long travel Id like to pres key on pendant to go as fast as possible. And when I was close to destination to use encoder wheel.
It\s should be possible as if I press cursor keys on keyboard the machine just do what I want. ..just the keyboard can be few meters away.
23 Aug 2013 15:44 #37987 by ArcEye
Replied by ArcEye on topic Jog with encoder and key.
Hi
A simple way would be to use halui
www.linuxcnc.org/docs/devel/html/gui/halui.html
eg.
setp halui.jog-speed 1000
net posjogX halui.jog.0.plus <= parport.0.pinN(connected to your button)
NB AFAIR speed must be set even if you just use the increment pins or the axis will not move
23 Aug 2013 17:09 - 23 Aug 2013 17:10 #37990 by eslavko
Replied by eslavko on topic Jog with encoder and key.
Thanks....
I forget to set speed...
Last edit: 23 Aug 2013 17:10 by eslavko.
Time to create page: 0.079 seconds
