linuxcncrsh 'open' path question
- EasyAs314159
- ArcEye
- Thank you received: 758
It is not particularly user friendly and that path is hard coded unless you alter it
See the built in help print
Using emcrsh:
emcrsh {-- --port <port number> --name <server name> --connectpw <password>
--enablepw <password> --sessions <max sessions> --path <path>
-ini<inifile>}
With -- --port Waits for socket connections (Telnet) on specified socket, without port
uses default port 5007.
With -- --name <server name> Sets the server name to specified name for Hello.
With -- --connectpw <password> Sets the connection password to 'password'. Default EMC
With -- --enablepw <password> Sets the enable password to 'password'. Default EMCTOO
With -- --sessions <max sessions> Sets the maximum number of simultaneous connextions
to max sessions. Default is no limit (-1).
With -- --path Sets the base path to program (G-Code) files, default is "../../nc_files/".
Make sure to include the final slash (/).
With -- -ini <inifile>, uses inifile instead of emc.ini.
PS
Seem to recall the syntax for the switches is peculiar too
It does require the double dash -- then the ones preceding the switch itself
Note also the ini file is hard coded to 'emc.ini' unless you set it
- EasyAs314159
- ArcEye
Has been 'rebranded' but still the same.
linuxcncrsh --help
Usage:
linuxcncrsh [Options]
Options:
--help this help
--port <port number> (default=5007)
--name <server name> (default=EMCNETSVR)
--connectpw <password> (default=EMC)
--enablepw <password> (default=EMCTOO)
--sessions <max sessions> (default=-1) (-1 ==> no limit)
--path <path> (default=../../nc_files/)
emcOptions:
-ini <inifile> (default=emc.ini)
It may have changed the dashes before switches however
That was always inexplicable, possibly something to do with the parsing routine used.
Now just -ini has a non standard single dash and prefixing with double dash is not mentioned You may have to experiment to be certain.
- EasyAs314159
DISPLAY=linuxcncrsh --path ""
however everytime I try and start linuxcnc I get:
linuxcncrsh: invalid option -- 'i'
I have also tried using loadusr in the hal with no luck either
Any other thoughts on what I can try?
- ArcEye
The machine I am running this on needs to be headless so I've tried this in the [DISPLAY] section:
You will do, linuxcncrsh is not a GUI, nor is it going to register an instance with linuxcnc.
The error is because the linuxcnc script passes various parameters to the GUI, the first being the name of the ini file.
linuxcncrsh is a remote access and command program, linuxcnc has to be already running on the machine which is connected to
You need to start and run linuxcnc on the remote machine and access it from the client
This may give you some ideas
www.wallacecompany.com/machine_shop/EMC2/remote_notes.html
- Thank you received: 4970
You _can_ use DISPLAY = halui for the most minimal (no-GUI) user interface.
- EasyAs314159
This also doesn't solve the linuxcncrsh path issue as I still need telnet access.
I think this is a matter of timing. It is trying to net the pins before halui is loaded in the first instance, and trying to load halui twice in the second instance.I am using references to the ports and pins halui exposes, when I set [DISPLAY]DISPLAY=halui it complains about missing pins, adding [HAL]HALUI=halui results in error messages about the module already being loaded.
You would need to net the halui pins in a Postgui halfile. (And I am not sure that the postgui hal-file ever gets loaded if Halui is the "GUI"
No. In the future there might be more options. The original idea (back in NIST days) was to use RCS / NML as a communication layer.This also doesn't solve the linuxcncrsh path issue as I still need telnet access.
www.isd.mel.nist.gov/projects/rcslib/NMLcpp.html
(Don't get carried away with studying that, I am not sure how much of it actually works in the current LinuxCNC version, and all of NML is likely to be removed in the future to be replaced with something less strange)
- EasyAs314159
I have written a small launch script that basically consists of:
linuxcnc [my ini file] &
halcmd -f custom_postgui.hal
as for the path issue this seems to work:
loadusr linuxcncrsh --path [path] --
