remove spindle control interface
18 Sep 2013 03:50 - 18 Sep 2013 04:17 #38958 by pfefferhaxen
remove spindle control interface was created by pfefferhaxen
Hello,
in the last days I did some tests with G- and M-Commands.
Now there is a spindle control interface in my LinuxCNC. It was not there before.
You can see a picture of it under my text.
I did not have a spindle which is connected to my controller, so I would like to remove this interface.
How can I do this?
Thank you!
Last edit: 18 Sep 2013 04:17 by pfefferhaxen.
18 Sep 2013 04:32 #38960 by BigJohnT
Replied by BigJohnT on topic remove spindle control interface
Look for some motion.spindle pins in your .hal file. If Axis sees them it shows the spindle controls. Depending on how you created your configuration some wizards might add pins that are not needed.
JT
19 Sep 2013 00:04 #38993 by pfefferhaxen
Replied by pfefferhaxen on topic remove spindle control interface
Thanks. :)
Now everything is fine in my LinuxCNC B)
