LinuxCNC stops during process
- maexbecks
I have a problem with a machine of mine. It runs on Ubuntu 8.04 and LinuxCNC 2.3.5 with
all new updates for that system.
I let the system start by an output from another machine, which I declared in the HAL File:
newsig autoRun bit
linksp autoRun parport.0.pin-15-in
linksp autoRun halui.mode.auto
linksp autoRun halui.program.run
The program starts mostly without any problems, but sometimes like every 1000. time the
program just stops and creates this output:
After you push the start button in the GUI, or with the output from the other machine, thecan't do that (EMC_TRAJ_SET_TELEOP_ENABLE) in auto mode with the interpreter waiting
program continues from the point where it stopped. It also mostly stops in the same line,
but again for like 999 times the program runs perfectly fine.
What is the problem here?
This is the program where it infrequently stops, but I don't know exactly in which line anymore:
o100 sub
M114 ; rot aus
o101 if [#100 GT 14.0]
M111 ;gruen auf blau
o101 else
M112 ;blau auf gruen
o101 endif
o102 if [#100 LT 15.0]
G54
#100 = [#100 + 0.003] ; Zustellung
S1000 M03
M103
G01 X[109.0 + #100] Z47.0 F1000
G01 Z55.0 Y12 F200
G01 X[110.2 + #100] Z59.0 Y24 F200
G01 X[109.7 + #100] Z62.0 Y36 F200
G01 X[109.5 + #100] Z65.0 Y48 F200
G01 X[103.0 + #100] Z68.2 Y60 F200
G01 X[100.0 + #100] Y72 F200
G01 Z79.0 Y84 F200
G01 X[105.8 + #100] Y96 F200
G01 X[100.0 + #100] Y108 F200
M05
G4P3
S1000 M04
G01 X[100.0 + #100] Y84 F200
G01 Z70.5 Y72 F200
G01 Z47.0 Y12 F200
G01 X[109.0 + #100]Z47.0 Y0 F200
M05
G01 X0 Z0 F1000
M104
o102 else
M113
(MSG, Buerste abgelaufen!)
M103
o102 endif
o100 endsub
o100 call
M30
- Thank you received: 4971
The program starts mostly without any problems, but sometimes like every 1000. time thenewsig autoRun bit linksp autoRun parport.0.pin-15-in linksp autoRun halui.mode.auto linksp autoRun halui.program.run
program just stops and creates this output:can't do that (EMC_TRAJ_SET_TELEOP_ENABLE) in auto mode with the interpreter waiting
I think what may be happening is that you are pressing the button between the system polling mode.auto and program.run.
The parallel port updates on a fixed schedule in the real-time thread, which interrupts the user-interface code.
The solution is probably to test that the mode is correct before setting run. Even with this there is then a small chance of setting auto-mode and then releasing the button before run...
loadrt and2 name=runbutton
addf runbutton servo-thread
net autoRun parport.0.pin-15-in => halui.mode.auto runbutton.in0
net run-mode halui.mode.is-auto => runbutton.in1
net start-run runbutton.out => halui.program.run
If you already have some and2 functions loaded then you will need to edit the quantity of them and either give them all names, or use and2.5 (or whatever) in place of runbutton in the above.
- maexbecks
Is there another possibility to start the program with an external signal on the parallel port?
But here the only problem would be that the programm would not start at all? So I could give the signal as long as I know
that the program was started and this problem would be gone?
But here the only problem would be that the programm would not start at all? So I could give the signal as long as I knowEven with this there is then a small chance of setting auto-mode and then releasing the button before run...
Yes, as long as you press the button until the program starts, it is all good.
It is just that once every seldom, if you press "run" then change your mind you will find the machine is unresponsive until you press "stop"
- Thank you received: 2160
This may be showing up here.
There was nothing that could be done at this time, if this is what the problem is.
Chris M
- maexbecks
already started, I think it must be something else.
It also seems that the downloadable image of Ubuntu 8.04 with LinuxCNC 2.3.0 doesn't have this
problem.
If there is no other solution I would have to setup the machines with an old version again, I guess.
There was some discussion that halui and a GUI can occasionally fight for the NML messages.
Is the problem possibly due to noise on the parport line?
Maybe a combination of the and2 (to get the sequence correct) and a long (2mS) debounce would help?
- maexbecks
This may be... how can i make the debounce in hal?
Edit: Got it. Lets see how it will work out... Thanks for your help.
