New to CNC machines, have some questions.
- leonvnoord
17 Oct 2013 14:53 #39996
by leonvnoord
New to CNC machines, have some questions. was created by leonvnoord
Hello all,
I am new to CNC machines. I have some trouble understanding some parts of how they work.
I have been doing some research, but some things are not clear to me.
My goal is to control a laser cutting machine from an embedded system.
From what I understand, I can let my embedded system generate G-code and then it can be interpreted by a CNC controller like LinuxCNC.
My first question is if this is correct.
My second question is how the G-code is read by CNC controllers. Is this by reading a 'G-code file' or can the G-codes be 'pushed' to a controller, so I would not need an interface for the controller, but only for my embedded system.
I hope you can help me clear things up.
- BigJohnT
- Thank you received: 1177
17 Oct 2013 17:55 #40000
by BigJohnT
Replied by BigJohnT on topic New to CNC machines, have some questions.
LinuxCNC uses a file with G code to control the machine.
You could use HAL components to control the machine directly.
JT
JT
- shopjock
20 Oct 2013 15:17 #40077
by shopjock
Replied by shopjock on topic New to CNC machines, have some questions.
I have a general question.
My DIY machine is 99% complete now. I have used FreeCad to design my first proto-types which will actually just small improvements to make my machine more rigid. Hopefully someone else out there has or is familiar with freecad.
so my question is how do i get linuxcnc to use the freecad file, and generate g-code for my millining machine.
I do also have blender installed but not yet spent any time familiarizing with it.
Do I need to import this freecad file to blender? Or can i Just import directly from linuxcnc using HAL components?
any input would be great.
- BigJohnT
20 Oct 2013 19:53 #40085
by BigJohnT
LinuxCNC needs a G code file not a CAD file to run. Depending on the shape of your part it is often easier to just type the G code file you need. Also often you can use a simple G code generator from the wiki page to generate your G code.
A good primer on G code is on my web site.
gnipsel.com/linuxcnc/g-code/index.html
JT
JT
The following user(s) said Thank You: shopjock
- shopjock
20 Oct 2013 20:02 #40086
by shopjock
Thank you for the response BigJohnT...
I guess i kind of formulated my question wrong.
How do I convert my cad file to usable G-code for my machine? May have been a better question.
- emcPT
- Thank you received: 139
20 Oct 2013 20:17 #40087
by emcPT
Replied by emcPT on topic New to CNC machines, have some questions.
CAM programs do what you want.
If your parts are simple, hand written is also a good method.
- BigJohnT
20 Oct 2013 20:24 #40089
by BigJohnT
That depends on the complexity of your CAD file. Is it 2-d milling a profile and drilling some holes or full 3-D milling? Can you attach a screen shot of the part?
As for Linux CAM software it is a bit lacking. There are some listed on the wiki site but I've never got any to work that I tried.
JT
JT
- shopjock
21 Oct 2013 12:36 - 21 Oct 2013 15:30 #40118
by shopjock
I hope this file attached correctly.
its not exactly a complex design.
after I finish upgrades on the machine I will probably purchase V-carve which from what I understand is an all in one program that suites my needs for this hobby machine.
The PDF is from "myDIYCNC" construction manual. behind it is my rendering of the part that I want to make in freecad.
As I understand it BlenderCam can convert to G-code for linuxcnc. Is That correct?
Again Thank you all for your helpful input, This has been a great learning experience for me and I cant wait to apply this to my wood working hobbies.
Last edit: 21 Oct 2013 15:30 by shopjock.
- BigJohnT
21 Oct 2013 19:06 #40125
by BigJohnT
No need for CAM for parts like that. I assume there is two blocks and most of the work will be squaring and sizing the blocks then drilling holes. Pin the two blocks together with a spacer and drill the larger hole in both pieces at the same time. You can use G0/G1 to do all the Ops on that part. Although G81 is worth learning for that part as well.
gnipsel.com/linuxcnc/machining/squaring.html
JT
JT
- Thank you received: 5018
22 Oct 2013 06:31 #40155
In an Ideal world you would use the FreeCAD CAM module, but it hasn't been written yet:
www.freecadweb.org/wiki/index.php?title=CAM_project
You should be able to download and install pyCAM and load your CAD model into that to create G-code.
Another possibility is HeeksCNC (which I think is sort-of working, though I believe the development effort has shifted to FreeCAD.)
Replied by andypugh on topic New to CNC machines, have some questions.
so my question is how do i get linuxcnc to use the freecad file, and generate g-code for my millining machine..
Time to create page: 0.401 seconds
