Is CAD-CAM conversion possible?
- guillemausio
22 Oct 2013 15:03 #40159
by guillemausio
Is CAD-CAM conversion possible? was created by guillemausio
Is there an option to import a 3D CAD and obtain the trajectory in G-code?
- cncbasher
- Thank you received: 288
22 Oct 2013 16:36 #40162
by cncbasher
Replied by cncbasher on topic Is CAD-CAM conversion possible?
no Linuxcnc is not a cam program , it only takes gcode input ,
what type of 3d input cad file are you looking at using STL files ? 3d printing etc ?
most use slic3r to produce the gcode from stl files ,
The following user(s) said Thank You: guillemausio
- guillemausio
22 Oct 2013 16:59 #40163
by guillemausio
Replied by guillemausio on topic Is CAD-CAM conversion possible?
I don't mind the input format, any parasolid is fine.
I want to obtain the g-code and then translate it into KRL with KUKA Camrob.
After that I'll mount a hot-wire tool in the robot arm and use it to cut the part in expanded polystirene.
Does anybody know which software I could use?
Thanks a lot
Thanks a lot
