Z Axis to raise bit after touch off question
06 Nov 2013 01:32 #40557 by rmattioda
What I am looking to try to do is when I Touch off-Z it will move the Z axis up to .80 automatically.
Is this possible?
06 Nov 2013 07:51 #40571 by andypugh
Replied by andypugh on topic Z Axis to raise bit after touch off question
Is this possible?
How are you touching-off?
G10 or the button in Axis? (or Touchy?)
Why do you want to do this? (Perhaps there is another way?)
06 Nov 2013 16:20 #40577 by Rick G
Seems like a simple approach would be to add a button that calls a sub and the sub would contain a g10 then a g0 z.080
Similar to below but instead of a MDI command use a sub
wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding_Custom_MDI_Buttons
Rick G
06 Nov 2013 23:06 - 06 Nov 2013 23:06 #40591 by rmattioda
Replied by rmattioda on topic Z Axis to raise bit after touch off question
Andy,
I am using the Touch off button that comes with EMC, I also have an MDI command which I linked with the 4th axis button on my Cnc4pc pendant.
the reason I would like this feature is so that when I touch off-Z, it of course zeros out the Z-axis so it knows where the material's depth is.
But I usually have to raise the bit to .80- 1.00 after the Touch off Z, this way when I start the design the bit wont touch the material when the router starts up.
this way the bit will have "zeroed the z-axis, then raise the bit, then I can start the design.
does this make sense?
thanks for your expertise
Last edit: 06 Nov 2013 23:06 by rmattioda.
06 Nov 2013 23:35 #40592 by BigJohnT
Replied by BigJohnT on topic Z Axis to raise bit after touch off question
Just jog Z up...
JT
Time to create page: 0.056 seconds
