Tool change
- Everettc4
09 Dec 2013 12:57 #41428
by Everettc4
Tool change was created by Everettc4
Hi all,
I'm wondering how to deal with a tool change in my g code.
Currently the g code produced by Rhino cam/ mecsoft produces a tool change line. The spindle stops and a box says press to continue after tool change. Great... But here's the prob there is no way to get the tool out.
I have tried stopping the job moving the spindle so I could change the tool and then tried starting from that line..
What I get is air cutting and the spindle is not restarted.
Any suggestions welcomed
Everett
Everett
- Thank you received: 5018
09 Dec 2013 19:37 #41432
I guess there must be _some_ way to get the tool out?
Is the problem just that the tool is too close to the work to get the tool out?
Have a look at: www.linuxcnc.org/docs/html/config/ini_co..._sub_emcio_section_a
If you define a tool-change position then the machine will move to there when there is a tool-change request.
In your case this may be only a partial answer unless you have a tool-holding system with repeatable length.
Replied by andypugh on topic Tool change
- Rick G
- Thank you received: 155
09 Dec 2013 20:52 #41434
by Rick G
And if that is true it may just be easier to break the code up into separate codes for each tool.
Rick G
Replied by Rick G on topic Tool change
Rick G
- Everettc4
09 Dec 2013 22:36 #41436
by Everettc4
Replied by Everettc4 on topic Tool change
Thanks for the Feed back I have attached the G-Code for reference...
I do have a 10 tool changer but haven't got that far with the conversion of a dyna myte 4400.
I will be happy changing manually but I need to have the spindle move so there is enough room to remove the tool.
So I guess my question is what is the best way to go about this??
Everett
Everett
09 Dec 2013 22:38 #41437
Define a TOOL_CHANGE_POSITION in the INI file.
