Interface Posibilities ?
11 Dec 2013 17:25 #41506 by arnold.braun
Interface Posibilities ? was created by arnold.braun
Hello Together,
sorry i´m new.
A simple quesstion.
I want to connect my own mictochip to controll the steppers.
I would like to transmit the postion for x,y,z and not the step -signals.
How can i setup LinuxCNC to do this.
Interface Parallel, USB, Network every way is posible form me.
thanks a lot arnold
11 Dec 2013 19:36 #41508 by BigJohnT
Replied by BigJohnT on topic Interface Posibilities ?
While LinuxCNC is designed to be the controller and output the step and direction signals I assume you could hack out part of LinuxCNC to parse the G code file. Download from the Git repository all the files to a user directory then you can look at them a see what you need.
JT
12 Dec 2013 00:52 #41520 by newbynobi
Replied by newbynobi on topic Interface Posibilities ?
Why not use a linuxcncrsh to control linuxcnc?
Just a small computer with no screen and so on controls the machine with linuxcnc and through the network you gen poll the positions to your controller ans send also commands to the machine.
Norbert
13 Dec 2013 01:37 #41555 by andypugh
Replied by andypugh on topic Interface Posibilities ?
The Pico, Mesa and Pluto drivers work exactly this way. I suggest having a look at how those work.
Making your chip emulate the Pluto interface might be the easiest way.
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...57a03d8517710572d7e0
The Pluto-step driver also has the advantage that is is a .comp and can be (fairly) easily installed without recompiling LinuxCNC.
Time to create page: 0.291 seconds
