Home all / home individual axis
- emcPT
- Thank you received: 139
12 Dec 2013 03:07 #41524
by emcPT
Home all / home individual axis was created by emcPT
I would like to know in a configuration with two axis (XZ) each of them with independent home switches, if it is possible to have a home all instead of home each axis independently. The screen is AXIS.
Or the solution would be to add a new button for this propose? (in this case I would like to remove the individual home axis buttons).
Thank you.
Thank you.
- BigJohnT
- Thank you received: 1176
12 Dec 2013 06:58 #41530
by BigJohnT
Replied by BigJohnT on topic Home all / home individual axis
If you have your home sequence set you get the Home All button.
JT
JT
The following user(s) said Thank You: emcPT, DougM
Time to create page: 0.096 seconds
