demystify G76 'R' parameter?
- llrjt100
29 Dec 2013 18:57 #42148
by llrjt100
demystify G76 'R' parameter? was created by llrjt100
Does anyone know the formula used internally for the g76 degression parameter 'R' and how it interacts with the compound slide angle 'Q' parameter?
I want to do modified flank infeed with control over the angle and depth of cut each pass and at the moment, it's looking like I'm going to have to use a bunch of G33 lines, each with different depth of cut and x/y start/end positions for the flank infeed - a lot of calculations!
- BigJohnT
- Thank you received: 1176
29 Dec 2013 19:37 #42149
by BigJohnT
Replied by BigJohnT on topic demystify G76 'R' parameter?
Sounds like you want to write a Python G code generator for threading so you don't have to do all the calculating.
gnipsel.com/files/g-code-generator/
Do you have all the formulas you need to cut perfect threads? Or is this a quest for longest tool life?
JT
JT
The following user(s) said Thank You: llrjt100
- llrjt100
29 Dec 2013 20:48 - 29 Dec 2013 20:54 #42153
by llrjt100
Replied by llrjt100 on topic demystify G76 'R' parameter?
Thank you - I'll try installing and running the Python code - this will give me ultimate control
I've been looking at Sandvik's calculator which simplifies a lot of the work, but the export to Excel spreadsheet option doesn't appear to generate valid files.
My quest is for the perfect thread for a worm, with constant helix and smooth flanks to achieve very constant speed in a precision instrument.
Sandvik recommend modified flank infeed over radial infeed to avoid judder and give smooth cutting - their calculator doesn't have brass as an option, but the feed table in the pdf catalogue shows 6 passes, with a final 0.07 mm pass - they strongly advise against using spring passes, which surprised me a bit!
Last edit: 29 Dec 2013 20:54 by llrjt100.
- BigJohnT
29 Dec 2013 21:02 #42155
by BigJohnT
A Python script does not need to be "installed". Just copy to a directory and make the file executable. The link is an example of what I did to generate G code for a mill. You could do the same thing for your threading which would be a lot simpler to do.
Here is my tutorials on creating a GUI in Python.
gnipsel.com/glade/index.html
JT
JT
Time to create page: 0.161 seconds
