Best linuxcnc version for 3x servo + wj200?
  • green751
  • green751's Avatar Topic Author
  • Visitor
  • Visitor
30 Dec 2013 23:52 #42199 by green751
Hi, all;
I'm currently running the most recent ubuntu CD install of Linuxcnc, and I'm to the point in my mill rework that I want to control my spindle. I have a Hitachi WJ200 VFD controlling a 5 HP 3 phase motor.
I know that the pre-2.6 tree has a driver for the wj200 in it, is this version ready for hobby use (not production), or should I stick with 2.5 with the classicladder modbus control?
Erik
31 Dec 2013 17:25 #42218 by ArcEye
Replied by ArcEye on topic Best linuxcnc version for 3x servo + wj200?
Hi
Build the master as a RIP install ( will not affect your existing system )
wiki.linuxcnc.org/cgi-bin/wiki.pl?Instal...ng_LinuxCNC_realtime
and try it.
Not too many people will actually have that hardware, so the developer who wrote it will be glad to have someone else test and report back any glitches
  • green751
  • Visitor
  • Visitor
31 Dec 2013 22:21 #42224 by green751
Replied by green751 on topic Best linuxcnc version for 3x servo + wj200?
Sounds like a plan.
I've been browsing through the git repository, looks like I should use master and graft the wj200 driver onto it?
I also see the unified-build-candidate, is this the branch for the version that will support multiple RT environments?
Erik
31 Dec 2013 22:56 #42228 by ArcEye
I just looked in the ubc-3 branches of the master I am running and cannot see it
(Yes they do support rt_preempt, xenomai, posix and rtai )
Looks like you didn't see it in the master either. Where exactly is the driver code?
If you have a copy of it and ensure the linuxcnc-dev package is installed, you can build it for your current system
  • green751
  • Visitor
  • Visitor
01 Jan 2014 00:48 #42234 by green751
01 Jan 2014 01:17 #42235 by ArcEye
Ok, I have downloaded it and compiled it.
This someones private git repo, nothing to do with the master, except it is a clone of it
The comp file is here (remove the .txt extension)
File Name: wj200_vfd.comp.txt
File Size:9 KB
I compiled it by running
comp wj200_vfd.comp to produce a .c file
then
gcc -Os -g -I. -I/usr/realtime/include -I. -I/usr/src/linuxcnc-dev-rtai/include -I/usr/include/modbus -D_FORTIFY_SOURCE=0 \
-mhard-float -DRTAI=3 -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime \
-D_FORTIFY_SOURCE=0 -D__MODULE__ -I/usr/include/linuxcnc -Wframe-larger-than=2560 -URTAPI -U__MODULE__ -DULAPI -Os \
-o wj200_vfd wj200_vfd.c -Wl,-rpath,/lib -L/lib -L/usr/lib -L/usr/src/linuxcnc-dev-rtai/lib -llinuxcnchal -llinuxcnc -lmodbus
but you will need to install libmodbus, libmodbus-dev and change the include and lib paths to suit wherever your realtime files are.
If that sends you screaming over the edge in confusion, I could probably build one for 10.04 / 2.5.3 tomorrow
The following user(s) said Thank You: green751
  • green751
  • Visitor
  • Visitor
01 Jan 2014 01:18 #42236 by green751
Thanks, I should be good to go with that.
Depending on how ambitious I feel I may even try to improve the driver a bit :)
Erik
Time to create page: 0.057 seconds
