BBB Joypad not opening
- llrjt100
27 Jan 2014 17:52 #43233
by llrjt100
BBB Joypad not opening was created by llrjt100
I've followed the
instructions
for setting up a joypad with a BBB and after seeing 'Loading cape-bone-iio overlay' during startup, I get 'No input devices could be opened. This usually indicates a misconfigured system. Please read the section 'PERMISSIONS AND UDEV' in the hal_input manpage.'
I followed the instructions and created a file 51-plugdev.rules and saved it in /etc/udev/rules.d containing SUBSYSTEM=="input", mode="0660", group="plugdev" . I've rebooted and I still get the same error. I have checked with terminal command 'less /proc/bus/input/devices' and I can see the joypad.
Any ideas welcome!
Any ideas welcome!
- xylotex
- Thank you received: 3
28 Jan 2014 01:47 #43241
by xylotex
Replied by xylotex on topic BBB Joypad not opening
I'm not sure what is causing your problem, but I was able to get a keypad set up using the instructions on this page:
softsolder.com/2013/02/25/linuxcnc-hal-p...stromo-n52-speedpad/
You might want to look there to see if it can help.
Jeff
Jeff
- llrjt100
28 Jan 2014 02:26 #43242
by llrjt100
Replied by llrjt100 on topic BBB Joypad not opening
Thanks Jeff - I'll give this a go.
Richard
Richard
- llrjt100
28 Jan 2014 03:27 #43244
by llrjt100
I've followed the instructions as far as possible:
1. 'less /proc/bus/input/devices' gives me a sensible list - my joypad is at the bottom, 'Bus=0003 Vendor=0f30 Product=0112 Version=0110', 'Name="Jess Tech Dual Analog Pad"
2. 'll /dev/input' returns command not found
3. 'lsusb' returns 'BUS 001 Device 006: ID 0f30:0112 Jess Technology Co., Ltd'
4. 'udevadm info --query=all --attribute-walk --name=/dev/bus/usb/006' returns command not found
I created a rules file 90-Jess.rules, and added a single line 'ATTRS{product}=="Jess",MODE="0660",GROUP="plugdev"
But it still doesn't work - I've also tried ATTRS{manufacturer}=="Jess" and SYSFS{idProduct}=="0112",SYSFS{idVendor}=="0f30" but with no luck...
I'm not sure what I'm missing - it's difficult because I can't dump the attributes with udevadm.
- xylotex
28 Jan 2014 03:44 #43246
by xylotex
ll is short for ls -l
so try:
ls -l /dev/input
some commands like udevadm may need the "sudo" in front like:
sudo udevadm ......
Jeff
so try:
ls -l /dev/input
sudo udevadm ......
Jeff
- llrjt100
28 Jan 2014 19:28 - 28 Jan 2014 19:40 #43270
by llrjt100
Thank Jeff - I can know get responses to all the commands.
After completing the final step in the instructions:
I get (snippet):
I'm not sure what the 'T' is on the end of the permissions - the mouse and keyboard event handlers have this too.
It's still not working, and this is the only thing I can see wrong, apart from a question about the Syntax in the rules file - the udevadm query returns ATTR{} and the .rules file uses ATTRS{}, which may well be correct.
The only other possibility is the order of execution of the .rules files - the instructions says:
I've tried renaming my file 'xdual.rules' to force it to be at the end of any rules without numbers (there are two system rules files 'rtheap.rules' and 'rt-pipe.rules', and also tried renaming it '90-dual.rules' to force it higher than the system files '50-LINUXCNC-shmdrv.rules' and '70-persistent-net.rules' - both to no avail...
sudo udevadm trigger
Which produces the desired result:
crw-rw---- 1 root plugdev 13, 67 2013-02-08 15:09 event3
crw-rw---- 1 root plugdev 13, 68 2013-02-08 15:09 event4
... snippage ...
crw-rw---- 1 root plugdev 13, 33 2013-02-08 15:09 mouse1
I get (snippet):
crw-rw---T 1 root plugdev 13, 68 Sep 3 15:51 event 4
crw-rw---T 1 root plugdev 13, 68 Sep 3 15:51 js0
Note that the file name must start with a number around 90- to avoid being clobbered by a rule in /lib/udev/rules.d/50-udev-default.rules that (re)sets the permissions to 0640; the doc suggests that rules without numbers happen after all the number rules, so perhaps you could just use meaningful names.
Last edit: 28 Jan 2014 19:40 by llrjt100.
- llrjt100
28 Jan 2014 21:26 - 28 Jan 2014 21:30 #43274
by llrjt100
I changed the permissions in the .rules file to 0777 and it works now - not sure this is strictly correct though!
When I check the event handler file permissions after doing the above, they now show crwxrwxrwt (not sure why sticky bit 'T' has now changed to 't') - it seems changing them to crw-rw---T with 0660 is insufficient as per all the documentation.
Last edit: 28 Jan 2014 21:30 by llrjt100.
Time to create page: 0.143 seconds
