[Question] Basic informations on linuxcnc
28 Jan 2014 19:58 - 28 Jan 2014 19:58 #43271 by Blackkeeper
[Question] Basic informations on linuxcnc was created by Blackkeeper
Hey fellows,
I`m trying to get a clue on LinuxCNC and there are some questions bothering me.
- How fast is LinuxCNC, is there a maximum speed given ?
- How accurate is LinuxCNC ?
- What is the maximum word length i can use with LinuxCNC ( 16, 32, 64 Bit ? )
- What is the maximum of positioning accuracy ?
I hope you guys can help me, i read most of documentation, but couldn't get some information about it.
Regards,
Blackkeeper
Last edit: 28 Jan 2014 19:58 by Blackkeeper.
28 Jan 2014 20:31 #43272 by BigJohnT
Replied by BigJohnT on topic [Question] Basic informations on linuxcnc
Everything you ask is a machine/hardware limitation not LinuxCNC.
I do no understand your question about word length.
JT
28 Jan 2014 21:21 #43273 by Blackkeeper
Replied by Blackkeeper on topic [Question] Basic informations on linuxcnc
Yes, you're right.
But is there no limitation of LinuxCNC, some kind of adjustment.
I know i can have various types of CPUs and they all have their own latency. But linuxcnc itself has to be an own software limitation on how fast it can process data and therefore a given maximum speed.
28 Jan 2014 22:19 #43276 by ArcEye
Replied by ArcEye on topic [Question] Basic informations on linuxcnc
Hi
Linuxcnc is a numerical control system for machines, it does not move the machines, it outputs the instructions to move
-How fast is LinuxCNC, is there a maximum speed given ?
It can output instructions faster than any machine can act upon them, so as JT says the notion of its maximum speed is meaningless, it is governed by the machine.
As accurate as the machine
If you are talking about programming, it is a 32bit program, so it uses 32 bit registers
That does not mean you can input a 32bit co-ordinate and expect to move the machine to it, see below
The resolution of the machine and hence its positioning accuracy is governed by what distance it moves per unit of motor movement, which in turn is down to gearing, leadscrew thread pitch, microstepping etc
I can only assum that you are trying to compare Linuxcnc to the specifications for a specific machine and built in controller
If the machine is capable of those specifications, it will be capable of them controlled by Linuxcnc
The following user(s) said Thank You: BigJohnT
Time to create page: 0.052 seconds
