Motor Jerking on Power Up Casuing Tracking Error
30 Jan 2014 03:27 #43310 by fbx109
Hello I am using a Mesa 7i77 card to control an analog drive. I have a PID controllor for the drive, but everytime I powerup the drive in linuxcnc, the drive jerks. The jerk cause a tracking error and linuxcnc halts.
30 Jan 2014 05:18 #43312 by jtc
the analog drive needs to "initialize" the motor? it occurs only on the first run of linuxcnc? what kind of analog drive are you using?
30 Jan 2014 05:26 #43313 by andypugh
It might be possible to power up the drive before turning LinuxCNC on. ie, turn on the drives on exiting e-stop (at which point LinuxCNC does not track following error).
29 Mar 2014 00:19 #45347 by fbx109
Hey all,
I think the problem was that my PID was not tuned properly. Once I tuned it it worked correctly. The values for P, I, and D were missing in the INI file, probably causing garbage values for the PID loop.
Thanks again for all the help.
Time to create page: 0.103 seconds
