How to put coordinates from external program into
- Comandante_Che
29 Apr 2010 11:04 #2750
by Comandante_Che
How to put coordinates from external program into was created by Comandante_Che
Hello. I need to position tool into position with coordinates, measured by vision. Is it possible in EMC2 to send coordinates from external image recognition program into G-code program?
12 May 2010 11:49 #2847
Replied by andypugh on topic Re:How to put coordinates from external program into
Comandante_Che wrote:
Probably...
There are "analog input" pins in EMC2 which can be read by the G-code M66 command.
See www.linuxcnc.org/docview/html//gcode_mai...ec:M66-Input-Control
And the Wiki for more information.
The more complicated part is getting your values into a form visible inside HAL. How would you like to present your numbers to EMC2?
The possible ways that spring to mind are from the serial port using pyserial or possibly using a user-defined M-word that calls a script to do the work.
(Look at M100-M199 further down that same page).
The HAL part of the script file would be: halcmd setp motion.analog-in-00 $1
(Or similar)
Probably...
(Or similar)
Time to create page: 0.203 seconds
