connecting DIY glue logic to linuxCNC through HAL
24 Feb 2014 00:04 - 24 Feb 2014 00:09 #44086 by plasturo
Hi to all outside in the world,
I build a DIY glue logic with a hand full of 74xx logic and try to get it in connection with linuxCNC running.
What I need to do, is sending an Address (example 0x00) and a data (example: 0x5A) through the LPT in EPP Mode (for test).
What do I need to tell LinuxCNC to send both values with the help of the HAL Interface?
I searched a lot in the web using www.linuxcnc.org, forum and Google, but it doesen't help.
I tried to set up the hm2_7i43, even if it doesn't fit my hardware. What I can see is, that my PCI-Card is set to ioaddr=0x0e10, because the control LED goes off after sending the 7i43 driver. So, the communication itself works.
Can somebody tell me where I can find the source code of the hostmot2 and the hm2_7i43?
[EDIT] @admin: Sorry, wrong Category, please move to General LinuxCNC Questions [/EDIT]
Thanks a lot,
bye,
Plasturo
Last edit: 24 Feb 2014 00:09 by plasturo.
24 Feb 2014 00:44 #44087 by ArcEye
Hi
You are probably going to have to write your own driver, so where you are already looking is along the right lines
sudo apt-get install git if not already installed
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev will fetch the master sources
./linuxcnc-dev/src/hal/drivers/mesa_hostmot2/ will bring you to the sources
The following user(s) said Thank You: plasturo
27 Feb 2014 06:00 - 27 Feb 2014 06:02 #44216 by plasturo
Replied by plasturo on topic compiling new object-file for DIY glue logic
( I build a DIY glue logic with a hand full of 74xx logic and try to get it in connection with linuxCNC running.
To do so, I want to use the "hm2_7i43.c" file as an example and build my own driver. )
I installed "ubuntu-10.04-linuxcnc3-i386.iso" and set it up with "git" to get the sources like describled in
"wiki.linuxcnc.org/cgi-bin/wiki.pl?Instal..._or_8_04_from_source"
I performed the following:
plasturo@linux-CNC:~$ sudo apt-get install libcurl4-gnutls-dev libexpat1-dev gettext libz-dev libssl-dev
plasturo@linux-CNC:~$ sudo apt-get install git-core
plasturo@linux-CNC:~$ git config --global user.name "My Name"
plasturo@linux-CNC:~$ git config --global user.email "This email address is being protected from spambots. You need JavaScript enabled to view it."
plasturo@linux-CNC:~$ sudo apt-get install libpth-dev
plasturo@linux-CNC:~$ sudo apt-get install git-core gitk git-gui
plasturo@linux-CNC:~$ git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
plasturo@linux-CNC:~$ cd linuxcnc-dev
plasturo@linux-CNC:~/linuxcnc-dev$ git checkout master
plasturo@linux-CNC:~/linuxcnc-dev$ git pull
plasturo@linux-CNC:~/linuxcnc-dev$ cd src
plasturo@linux-CNC:~/linuxcnc-dev/src$ sudo apt-get install libmodbus-dev
plasturo@linux-CNC:~/linuxcnc-dev/src$ sudo apt-get install libusb-1.0-0-dev
plasturo@linux-CNC:~/linuxcnc-dev/src$ sudo apt-get install python
plasturo@linux-CNC:~/linuxcnc-dev/src$ ./autogen.sh
plasturo@linux-CNC:~/linuxcnc-dev/src$ ./configure --enable-run-in-place
plasturo@linux-CNC:~/linuxcnc-dev/src$ make
Then I copied the files hm2_7i43.h and hm2_7i43.c to the file hm2titan.h and hm2titan.c and inclcude
this change in the Makefile.
After compiling the full kernel again, I god the object-file hm2titan.o as aspected.
But if I have a look into the files under /usr/realtime-2.6.32-122-rtai/modules/linuxcnc/
I can only find object-files with ending *.ko
Where is the misstake, what can I do to get the right *.ko file??
Is there a possiblility to compile only the needed file (and not the full kernel)?
Thanks for your help,
Plasturo
Last edit: 27 Feb 2014 06:02 by plasturo.
27 Feb 2014 15:27 #44227 by ArcEye
From the shell within which you have set your RIP environment variables,
cd to the dir with your files in it and run
comp --install hm2titan.c
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
27 Feb 2014 20:45 #44233 by andypugh
Replied by andypugh on topic compiling new object-file for DIY glue logic
hm2_7i43 is intended to work with the rest of the Hostmot2 driver, so I think you will struggle to make it work for your purpose.
Have a look at the Pluto-P drivers instead. Those are simple, standalone EPP device drivers.
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...e0c2259abfc1;hb=HEAD
They are even written in the "comp" format to make things even easier.
www.linuxcnc.org/docs/html/hal/comp.html
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
28 Feb 2014 00:48 #44238 by andypugh
Thinking about this some more, are you sure you need EPP?
I can imagine a very simple component that simply sends address and data on alternate thread invocations.
At it's simplest parallel port access is a very simple outb instruction, though it is safer to use the rtapi version in realtime code.
www.linuxcnc.org/docs/html/man/man3/rtapi_outb.3rtapi.html
component simple_io "a very simple parallel port driver";
pin unsigned in address;
pin unsigned in data;
static int s = 0;
static int old_address = 0;
switch s{
case 0:
    if (address != old_address)
        rtapi_outb(address, 0x378);
        s = 1;
        old_address = address;
        break;
case 1:
    rtapi_outb(data, 0x378);
    break;
28 Feb 2014 04:54 #44240 by plasturo
Thank you all for your answer an help,
@ArcEye: Thanks for the information, I start to read the documentation about "comp". I think that is what I am was looking for.
@andypugh: I try to use as much code as possible, and the philosophy of the "hostmot2" is nice, I think. That's why I am trying to change the "hm2_7i43" code to be able to drive my hardware. On the other hand, I had of course a look to the Pluto-P driver. I will see what will be the good starting point for me.
And yes, I am sure to use EPP mode (I hope), because it is much quicker then using the LPT in standard mode. So the "rtapi_outb" is not the right one for me. I will use a lot of input signals, too.
So, thanks a lot to all, I am looking forward to the weekend and hope I find the time to go on with my little project.
Bye,
Plasturo
28 Feb 2014 05:14 #44243 by plasturo
to see what I have done until now, here is a picture
from left to right
1.) LPT board, includes 74xx245 for data and 74xx574 for address latching
The addresses are decode with a 74xx138 for reading and a 74xx238 for writing
2. and 3.) Two output-boards with 8 bit each. A 74xx573 is used as a driver for the LED's.
4.,5. and 6.) Three input-boards with 8 bit each. A74xx573 is used for the LED's, too
7.) Power-Supply +5V
bottom:) The "EPP-Bus" with 8bit Data plus selection bus for read and write.
All Boards (2..6) contain own optocopler behind the Connectors.
bye,
Plasturo
04 Mar 2014 05:24 - 04 Mar 2014 05:36 #44378 by plasturo
Hi all,
I start to play a little bit with "comp", but it doesn' work.
Can somebody tell me what is wrong?
Home directory = /home/plasturo
src dir = /home/plasturo/linuxcnc-dev
What I try is the following:
root@linux-CNC:/home/plasturo/linuxcnc-dev/src/hal/drivers/mesa-hostmot2# comp --install hm2titan.c
Answer from the program:
Das Programm »comp« ist in folgenden Paketen enthalten:
* mailutils-mh
* nmh
Versuchen Sie: apt-get install <ausgewähltes Paket>
(first line: The Program "comp" is included in the following packages:)
(last line: Please try: apt-get install <selected package>)
Both, "apt-get install nmh" and "apt-get install mailutils-mh" doesn't help.
Can somebody help me?
Thanks and bye,
Plasturo
Last edit: 04 Mar 2014 05:36 by plasturo.
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
04 Mar 2014 07:13 #44384 by andypugh
sudo apt-get install build-essential
sudo apt-get install linuxcnc-dev
Time to create page: 0.225 seconds
