Stop/Start spindle during threading
- llrjt100
25 Feb 2014 17:19 - 25 Feb 2014 17:44 #44171
by llrjt100
Stop/Start spindle during threading was created by llrjt100
I can pause a G76 cycle in the Axis GUI during the non-sychronised threading moves - can I also stop the spindle and jog away so I can measure the thread, then restart the spindle and have LCNC return to the correct thread start position and sync the threading pass correctly? I want to be able to check the thread during the cutting cycle.
Last edit: 25 Feb 2014 17:44 by llrjt100.
- emcPT
- Thank you received: 139
25 Feb 2014 17:48 #44172
by emcPT
Replied by emcPT on topic Stop/Start spindle during threading
One thing that might actually work is to put the spindle override to zero.
Let me know if it works.
- llrjt100
25 Feb 2014 18:37 #44174
by llrjt100
Replied by llrjt100 on topic Stop/Start spindle during threading
Thanks for the suggestion - could you elaborate a little on 'spindle override' - is it a .ini file setting?
- emcPT
25 Feb 2014 18:59 #44175
by emcPT
- llrjt100
25 Feb 2014 19:17 - 25 Feb 2014 19:17 #44176
by llrjt100
I don't understand the relevance of 'spindle overide' in relation to my question - apologies for my ignorance!
Last edit: 25 Feb 2014 19:17 by llrjt100.
- emcPT
25 Feb 2014 19:24 #44177
by emcPT
This is my point of view:
During the threading, the motion is synchronized with the spindle.
If the spindle is with override = 0, then no motion will occur and you can check the thread, if you place spindle override = 100, then it will continue to work.
It will not able you to jog during the work, but it allows to "pause" the work for checking.
- llrjt100
25 Feb 2014 19:35 #44178
by llrjt100
Thank you - this makes sense. I don't have a spindle speed overide in AXIS, but I do have manual control over the spindle speed outside of LCNC - when I try dialing this to zero, the G76 cycle pauses, so I can make a measurement now
Time to create page: 0.057 seconds
