Building LinuxCNC on a newer distro of linux
03 Mar 2014 16:41 - 03 Mar 2014 16:42 #44345 by JZHA1985
I have found the old distros that LinuxCNC is packaged with doesn't support my (to be replacement computer) atom motherboard's Ethernet connection, wifi, or so forth. But with the newer versions of Ubuntu it all magically works (I tried a few things to get the ethernet working with no luck). Can I take a newer LTS version of Ubuntu and easily enough buuild LinuxCNC on it? I know this is a rudimentary question, but I don't know a ton about linux past it just works really well :)
Last edit: 03 Mar 2014 16:42 by JZHA1985.
03 Mar 2014 16:56 #44346 by DaBit
Same problem here. I used this:
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_On_Ubuntu_Precise
And so far it runs flawless.
03 Mar 2014 16:58 - 03 Mar 2014 17:04 #44347 by ArcEye
Hi
You haven't said which version of Ubuntu you are talking about
If it is 12.04, this works
EDIT DaBit beat me by 2 minutes, but that is 2 votes for the same thing, which gives you a clue
Last edit: 03 Mar 2014 17:04 by ArcEye.
Time to create page: 0.060 seconds
