CNC Linux and USB CNC Compatible?
17 Mar 2014 12:31 #44910 by stevos758
CNC Linux and USB CNC Compatible? was created by stevos758
I have a X6 1500GT on the way and I am wondering if I can use Linux CNC with a USB CNC?
www.carving-cnc.com/x61500series-1/cnc-x...milling-machine.html
17 Mar 2014 14:01 #44911 by cmorley
Replied by cmorley on topic CNC Linux and USB CNC Compatible?
No, linuxcnc doesn't support USB motion control cards.
Though the step drivers shown are use step and direction signals so you could bypass the USB card and use it with linuxcnc.
Chris M
17 Mar 2014 21:44 #44919 by stevos758
Replied by stevos758 on topic CNC Linux and USB CNC Compatible?
Is there any plans to add this to future versions? The laptop I acquired doesn't have a serial port either. How are the USB to serial adapters now days? I would assume that is how I would need to hook up the machine in order to use LinuxCNC? Or do I need to use a different controller card?
18 Mar 2014 00:17 #44923 by ArcEye
Replied by ArcEye on topic CNC Linux and USB CNC Compatible?
Hi
This subject has been done to death previously.
See www.linuxcnc.org/index.php/english/forum...b-again?limitstart=0
and search the forum for more.
Time to create page: 0.049 seconds
