Import g-code from V-Carve into EMC2
- ts_engraving
05 Apr 2014 07:57 #45573
by ts_engraving
Import g-code from V-Carve into EMC2 was created by ts_engraving
I'm new to this and just purchased a Sherline CNC mill. I have been told by Sherline that in order to be able to use my copy of V-Carve to create a g-code file and use it in EMC2, that I need a post processor file to add to V-Carve. Where can I find this file and where do I place it once I get it?
Thanks in advance.......Terry Wade T's Engraving, llc
- Rick G
- Thank you received: 155
05 Apr 2014 13:15 #45578
by Rick G
Replied by Rick G on topic Import g-code from V-Carve into EMC2
Pretty sure that is included in the list of post processors that comes with V carve.
Check the list, if linuxcnc is not there try EMC2.
Rick g
Rick g
- ArcEye
- Thank you received: 758
05 Apr 2014 14:03 #45579
by ArcEye
Replied by ArcEye on topic Import g-code from V-Carve into EMC2
- cncbasher
- Thank you received: 288
06 Apr 2014 20:40 #45615
by cncbasher
Replied by cncbasher on topic Import g-code from V-Carve into EMC2
i posted a vcarve post processor to the wiki , although i believe it's probably included now . it may still be under the old name of emc etc
Time to create page: 0.057 seconds
