Second port for limit switches?
13 Apr 2014 10:10 #45897 by AMelvin
Second port for limit switches? was created by AMelvin
If I'm using six axis on the breakout board, do I need a second breakout board for the limit switches or can I use a simple TTL circuit for this?
13 Apr 2014 13:34 - 13 Apr 2014 13:35 #45901 by ArcEye
Replied by ArcEye on topic Second port for limit switches?
You can chain them all together in series and just use one input.
If you have managed to connect 6 axes, presumably you need another port anyway for charge pump / enable, coolant relay, spindle relay etc
Last edit: 13 Apr 2014 13:35 by ArcEye.
13 Apr 2014 22:59 #45912 by AMelvin
Replied by AMelvin on topic Second port for limit switches?
I read where limit switches are connected in a single loop but felt uncomfortable with that type hook up.
The Linux documentation is some what limited on this subject. Where can I research more on this?
14 Apr 2014 00:32 #45917 by ArcEye
I dont know of any actual docs, it is extremely simple and safe.
One switch breaks, the circuit breaks and everything stops.
It would be very rare that you could not just look at the machine and know immediately which switch had triggered.
Additionally, if you have your soft limits set properly, it should be impossible to hit the physical limit switches unless you lose steps.
I cant remember the last time I actually did that.
The following user(s) said Thank You: AMelvin
14 Apr 2014 18:28 - 14 Apr 2014 18:29 #45937 by BigJohnT
Replied by BigJohnT on topic Second port for limit switches?
Hooking up limit switches as normally closed and in a loop is the normal way. If you cut a wire or any switch opens then the machine stops.
If you have the I/O hooking each switch up to an input is also a common way to connect limits.
JT
Last edit: 14 Apr 2014 18:29 by BigJohnT.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
15 Apr 2014 10:25 #45960 by Todd Zuercher
Replied by Todd Zuercher on topic Second port for limit switches?
As to adding multiple ports. While it may or may not be necessary for your set up. adding and using multiple LPT ports to your pc is not a problem for Linuxcnc. I have a set up that uses a 2 port parallel port PCI card, in addition to the motherboards built in port. While I am not using nearly all of the io on any of the three ports, adding the 3rd port to this machine made connecting it infinitely simpler, since I was adding controls to an existing setup that did not give easy access to the unused io on the 2 LPT ports it was using. And basic breakout boards are cheap.
Time to create page: 0.182 seconds
