Getting "Need tool prepared -Txx- for toolchange"
- RayJr
- Thank you received: 4
21 Apr 2014 23:58 #46184
by RayJr
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Getting "Need tool prepared -Txx- for toolchange" was created by RayJr
recently, I have started getting the above error when changing to tool #4 in the tool table. I don't have a clue why thsi has started occurring.
Thank yo for your help!!!
Ray
Ray
Albert Einstein
- Thank you received: 4967
22 Apr 2014 06:41 #46203
That is very strange. What pocket does the tool table have the tool in?
Replied by andypugh on topic Getting "Need tool prepared -Txx- for toolchange"
- RayJr
22 Apr 2014 06:47 #46206
by RayJr
Albert Einstein
Replied by RayJr on topic Getting "Need tool prepared -Txx- for toolchange"
It is in pocket 4.
The table has 32 tools in it.
this is the only one that seems to cause this problem, and it started recently. It may have happened when I had to change out a cutter that broke, and i put a smaller one in.
Attached is the gcode file I was using today.
Ray
Ray
Albert Einstein
22 Apr 2014 20:17 #46215
I wonder if there is an invalid and invisible character in the tool table file? I would hope that the system was robust to that, but perhaps not.
Looking around the LinuxCNC Gitweb.
git.linuxcnc.org/gitweb?p=linuxcnc.git&a...s=Need+tool+prepared
Indicates that the message is NCE_TXX_MISSING_FOR_M6
And then looking for where that message is raised leads to this line of code:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...c675fbd2e41ecc#l5006
For some reason the system is seeing a negative pocket number for tool 4. Maybe try hand-editing the tool table file (using gedit or similar), deleting the pocket number (and a few surrounding characters) then re-saving the file and restarting LinuxCNC.
- RayJr
22 Apr 2014 21:56 #46221
by RayJr
Albert Einstein
Thank you for checking into this Andy.
I did check the tool.tbl file with gedit, and saw nothing out of the usual. The line starts off with: T4 P4 .1719 -2.xxxx ( forget what the full length offset was), then the description.
I think my next step is to delete that entry, save the file, then re-enter it, and save it.
But that will need to wait. I am traveling with the high school robotics team I mentor. They earned a ticket to the world championship event in St Louis that starts tomorrow.
The Bridgeport that LinuxCNC is on is the teams machine. My son & I retrofitted it four years ago.
I will follow up on this after we get back from the competition. (hopefully with the Championship trophy!)
Ray M.
Ray M.
Albert Einstein
23 Apr 2014 22:11 #46254
Good luck.
Google suggested that it is FIRST, but the web site doesn't seem to give any clues what the actual competition is.
I once won a Robot Football championship (BBC Technogames series) using a thinly-disguised RobotWars robot.
Good luck.
- RayJr
15 Aug 2014 13:46 #49887
by RayJr
Albert Einstein
I just got back to working on solving this issue.
I found that a change to the post processor I use has caused it to put in an "M6" command near the end of the ngc file , with no associated "T" command.
Thank you Andy for your research into this, as it was what led me to the problem!
What had me thrown for a while is that the error ops up right after the last real tool change in the file, that is quite far from the end of the file. I didn't realize that LCNC is doing that much of a lookahead.
ray
ray
Albert Einstein
15 Aug 2014 15:05 #49888
I am not sure that should cause a problem. I would expect to attempt to load the current tool.
The postprocessor might be trying to do a tool unload (M6 T0 in LinuxCNC)
- RayJr
15 Aug 2014 22:05 #49892
by RayJr
Albert Einstein
This happened right after I hit enter from a manual tool change. If I edit the errant M6 out of the file, I can finish the process without the error.
I happens with version 2.6.2 as well.
I was trying to get the program to unload the tool at the end of the program, or at the very least, move the quill up.
Ray
Ray
Albert Einstein
Time to create page: 0.150 seconds
