Error when tool change requested
22 Apr 2014 05:10 #46198 by RayJr
Error when tool change requested was created by RayJr
I am getting "Need tool prepared -Txx- for toolchange" error after I change the tool & hit OK.
This is the third tool used in the program, and is tool #4 in the tool table. I don't have a clue why this has started occurring.
I do no have an automatic tool changer, so the program brings the quill up, then open a dialog box opens requesting the tool change, I then change the tool & hit enter.
Then the program continues, except for tool #4. I have checked the tool table with gedit and see nothing wrong with the entry for tool 4. it is an 11/64ths (.1719) end mill.
This is on Lucid, and version 2.5.3
Thank you for your help!!!
Ray
"No problem can be solved from the same level of consciousness that created it"
Albert Einstein
Time to create page: 0.042 seconds
