Jerky motion with spiral cutting for circles
28 Apr 2014 03:48 - 28 Apr 2014 03:49 #46387 by Duc
Im running into issues with the machine being jerky when running spiral cutting for a circle code versus a code output that only output simple circles with step overs.
Machine specs
Intel P4 1.8 ghz
1.5 gigs ram
ATI 9800 Pro
Mesa 5i25/7i76/7i84
The machine will behave perfectly if Im running simple G-code but if running code that uses alot of G-code changes then I get jerky movement. Seems like it is running one line then a short pause till the next line.
Any ideas
Last edit: 28 Apr 2014 03:49 by Duc.
28 Apr 2014 04:38 #46391 by PCW
Its likely your spiral gcode is made of lots of short segments
Have you looked at the G64 options?
linuxcnc.org/docs/html/common/User_Conce...c:trajectory-control
28 Apr 2014 06:43 #46399 by Duc
Tried both G61 and G64. Problem was noticably worse with G61.
Looking at my .ini file I do have different acceleration numbers for X and Y. X is 4 and Y is 2. Anything higher than 2 on y results in joint following errors.
28 Apr 2014 07:28 #46406 by PCW
Those seem like very low acceleration numbers
I would suspect tuning issues or too tight following error limits
28 Apr 2014 07:36 #46408 by Duc
Wasnt to sure what FERROR and MIN_FERROR I should use on the machine. I know its not a super fast CNC since its a old bridgeport boss 5 with original steppers. The joint follow error could be tied to the FERROR limits according to the wiki.
What is a good rough number to use for them to increase the acceleration.
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = .5
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.66666666667
MAX_ACCELERATION = 4.0
# these are in nanoseconds
DIRSETUP   = 200
DIRHOLD    = 200
STEPLEN    = 1000
STEPSPACE  = 2000
STEP_SCALE = -10000.0
MIN_LIMIT = -0.0
MAX_LIMIT = 18.0
HOME_OFFSET = -0.050000
HOME_SEARCH_VEL = -0.2
HOME_LATCH_VEL = -0.016667
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 1
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = .050
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_VELOCITY = 1.667
MAX_ACCELERATION = 2.0
DIRSETUP   = 200
DIRHOLD    = 200
STEPLEN    = 1000
STEPSPACE  = 2000
MIN_LIMIT = -0.0
MAX_LIMIT = 12.0
HOME_OFFSET = -0.060000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 2
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
DIRSETUP   = 200
DIRHOLD    = 200
STEPLEN    = 1000
STEPSPACE  = 2000
MIN_LIMIT = -5.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.050000
HOME_SEARCH_VEL = 0.100000
HOME_LATCH_VEL = 0.016667
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
28 Apr 2014 08:38 #46409 by PCW
I had forgotten that this was a step/dir machine
If you have following errors its likely that the stepgen_maxaxccel values are not set
(they should be set to about 1.2X the maxaccel values for the corresponding axis)
for a slow stepgen machine I might set maxaccel to 2 to 5x maxvel
28 Apr 2014 09:19 #46411 by Duc
so I need to adjust the values in the .hal file
Current
#  AXIS X
# Step Gen signals/setup
setp   hm2_5i25.0.stepgen.00.dirsetup        [AXIS_0]DIRSETUP
setp   hm2_5i25.0.stepgen.00.dirhold         [AXIS_0]DIRHOLD
setp   hm2_5i25.0.stepgen.00.steplen         [AXIS_0]STEPLEN
setp   hm2_5i25.0.stepgen.00.stepspace       [AXIS_0]STEPSPACE
setp   hm2_5i25.0.stepgen.00.position-scale  [AXIS_0]STEP_SCALE
setp   hm2_5i25.0.stepgen.00.step_type        0
setp   hm2_5i25.0.stepgen.00.control-type     0
setp   hm2_5i25.0.stepgen.00.maxaccel         5.0
setp   hm2_5i25.0.stepgen.00.maxvel           2.1
net x-pos-fb     axis.0.motor-pos-fb   <=  hm2_5i25.0.stepgen.00.position-fb
net x-pos-cmd    axis.0.motor-pos-cmd  =>  hm2_5i25.0.stepgen.00.position-cmd
net x-enable     axis.0.amp-enable-out =>  hm2_5i25.0.stepgen.00.enable
# ---setup home / limit switch signals---
net both-home-x     =>  axis.0.home-sw-in
net both-home-x     =>  axis.0.neg-lim-sw-in
net both-home-x     =>  axis.0.pos-lim-sw-in
#  AXIS Y
setp   hm2_5i25.0.stepgen.01.dirsetup        [AXIS_1]DIRSETUP
setp   hm2_5i25.0.stepgen.01.dirhold         [AXIS_1]DIRHOLD
setp   hm2_5i25.0.stepgen.01.steplen         [AXIS_1]STEPLEN
setp   hm2_5i25.0.stepgen.01.stepspace       [AXIS_1]STEPSPACE
setp   hm2_5i25.0.stepgen.01.position-scale  [AXIS_1]STEP_SCALE
setp   hm2_5i25.0.stepgen.01.step_type        0
setp   hm2_5i25.0.stepgen.01.control-type     0
setp   hm2_5i25.0.stepgen.01.maxaccel         2.5
setp   hm2_5i25.0.stepgen.01.maxvel           2.1
net y-pos-fb     axis.1.motor-pos-fb   <=  hm2_5i25.0.stepgen.01.position-fb
net y-pos-cmd    axis.1.motor-pos-cmd  =>  hm2_5i25.0.stepgen.01.position-cmd
net y-enable     axis.1.amp-enable-out =>  hm2_5i25.0.stepgen.01.enable
net both-home-y     =>  axis.1.home-sw-in
net both-home-y     =>  axis.1.neg-lim-sw-in
net both-home-y     =>  axis.1.pos-lim-sw-in
#  AXIS Z
setp   hm2_5i25.0.stepgen.02.dirsetup        [AXIS_2]DIRSETUP
setp   hm2_5i25.0.stepgen.02.dirhold         [AXIS_2]DIRHOLD
setp   hm2_5i25.0.stepgen.02.steplen         [AXIS_2]STEPLEN
setp   hm2_5i25.0.stepgen.02.stepspace       [AXIS_2]STEPSPACE
setp   hm2_5i25.0.stepgen.02.position-scale  [AXIS_2]STEP_SCALE
setp   hm2_5i25.0.stepgen.02.step_type        0
setp   hm2_5i25.0.stepgen.02.control-type     0
setp   hm2_5i25.0.stepgen.02.maxaccel         2.5
setp   hm2_5i25.0.stepgen.02.maxvel           2.1
Suggested?
#  AXIS X
setp   hm2_5i25.0.stepgen.00.maxvel          1
#  AXIS Y
setp   hm2_5i25.0.stepgen.01.maxaccel         5
setp   hm2_5i25.0.stepgen.01.maxvel           1
#  AXIS Z
setp   hm2_5i25.0.stepgen.02.maxaccel         5
setp   hm2_5i25.0.stepgen.02.maxvel           1.0
28 Apr 2014 10:23 #46415 by PCW
if the maxvel numbers in the ini file are all 4, yes
28 Apr 2014 14:41 #46419 by Rick G
In addition to what PCW has suggested you might want to look here...
www.linuxcnc.org/index.php/english/forum...stersprograms-wanted
Rick G
Time to create page: 0.061 seconds
