How does linuxcnc remeber home position?
29 Apr 2014 11:55 #46453 by skvallab
When we dont have a linear encoder on bed, how does it remeber its last poition when there is power failure?
vallab
29 Apr 2014 12:59 #46456 by emcPT
Replied by emcPT on topic How does linuxcnc remeber home position?
You cannot thrust any stored value for accuracy.
You must home to ensure a proper "real" coordinate.
The following user(s) said Thank You: skvallab
29 Apr 2014 13:19 #46457 by skvallab
Replied by skvallab on topic How does linuxcnc remeber home position?
Can you explain how it goes to home position?
Does it identify home position by limit switch
29 Apr 2014 14:44 #46460 by cncbasher
Replied by cncbasher on topic How does linuxcnc remeber home position?
yes when an encoder is not available it is usual to use a home or limit switch
29 Apr 2014 16:52 #46467 by emcPT
The most (very accurate) accurate method is to use an encoder with index signal and a microswitch.
It works more or less like this:
The machine moves until it hits the microswitch, then is moves in the opposite direction until it finds the index signal of the encoder.
Since the index signal of the encoder is only one position per turn, it will provide a very accurate homing value.
30 Apr 2014 05:41 #46485 by andypugh
Replied by andypugh on topic How does linuxcnc remeber home position?
If you don't have home switches, and you can guarantee that nothing gets moved when the power is off, then you can use POSITION_FILE:
www.linuxcnc.org/docs/devel/html/config/...tml#sub:TRAJ-section
Time to create page: 0.050 seconds
