Lost the launch file
- twitchingmuffin
19 May 2014 23:30 #47059
by twitchingmuffin
Lost the launch file was created by twitchingmuffin
I'm not sure what happened I always shut the computer down after using it, When I went to start it up the linuxcnc penguin shows up but it will not launch the program, if I open linuxcnc config it has the metric and 4th axis and they will open but nothing else any ideas as to why this happened and how to get it back?
- Thank you received: 4967
20 May 2014 06:06 #47066
Replied by andypugh on topic Lost the launch file
Any error messages?
If you start LinuxCNC from the command line (just type "linuxcnc" ) then what happens?
- twitchingmuffin
20 May 2014 06:16 #47068
by twitchingmuffin
Replied by twitchingmuffin on topic Lost the launch file
there were no messages of any kind I finished using it shut it down and the next time I went to use it you can double click icon and there is nothing you can right click and select open and there is nothing I even went into linuxcnc folder and you can select the .ini folder to initialize and there is nothing- this one has me stumped as to what happened
- Einar
20 May 2014 15:14 #47080
by Einar
Replied by Einar on topic Lost the launch file
Andypugh's suggestion is a good one.
In my case, when this happens it is because the Universal Stepper Controller did not initialize correctly and needs a Power Down / Power up.
When LinuxCNC does not find the hardware it relies upon, it will silently quit. That is the point With starting it from a terminal window: it will leave some Messages that usually are helpful.
- twitchingmuffin
20 May 2014 19:59 #47092
by twitchingmuffin
I did got to terminal and typed that in and it took me straight to configurator and said 2.5.0 which I am assuming is the version number nothing else
20 May 2014 20:02 #47093
Is it possible that you have been logged in as a different user and do the linuxcnc folder does not exist in your home folder?
Can you post a screenshot of the config chooser?
- twitchingmuffin
20 May 2014 20:05 #47094
by twitchingmuffin
I can later , but no I have never logged that computer out of original setup the only thing the computer has ever been used for is to run the machine I don't even internet hooked up to it or anything
21 May 2014 06:19 #47123
can you see your linuxcnc folder in the Ubuntu file browser? Can you see the configs?
- twitchingmuffin
17 Jun 2014 04:31 #48015
by twitchingmuffin
i lost the configs file i go tthem back and works great thanks for everyones help
Time to create page: 0.080 seconds
