jitter
21 May 2014 09:19 #47134 by jcarrr
jitter was created by jcarrr
When I use the utility to check for latency, jitter, etc the number will sometimes be in the 9000 range for an entire session. Other times it will start and remain in the 27,000 range or jump to the high value after being in the 9000 range for a few minutes.
I am not a complete newbie at all this, but I can find no other process that is jumping in the way or can I find one to shut down that makes a difference. 4 processors, lots of memory.
Suggestions or references please
JC
21 May 2014 15:55 #47147 by ArcEye
Replied by ArcEye on topic jitter
Hi
See this FAQ re some latency solutions
www.linuxcnc.org/index.php/english/forum...me-latency-solutions
The figure you are talking about is a cumulative one so is no good for any sort of diagnostic
Use the realtime latency test described in the FAQ and see where the spike occurs
If you are using 4 processors you will not get good latency, as is discussed in the preceding FAQ
www.linuxcnc.org/index.php/english/forum...-the-latency-problem
Look at the isolcupus method of isolating all but one core, links in the FAQ
Time to create page: 0.057 seconds
