Advice
15 Jun 2014 18:47 #47987 by nissjay
Advice was created by nissjay
Hi BigJohn T/ Arceye,
I would like to get some advice about how I use step config in Linuxcnc to configure six axis and how I configure parallel port in computer ?
Do I need any particular hardware in my computer for that?
Please advice
Thanking You
Regards
Nissjay
15 Jun 2014 19:42 #47988 by ArcEye
Replied by ArcEye on topic Advice
You can't use stepconf, you would have to start with stepconf for 4 axes and add the others manually.
Would need more info to assist, 6 axes could be anything from a robot arm to ...... ?
Regards hardware, you will need a second parport, a PCI card is the normal solution ( one with 2 parallel ports and using a MosChip / NetMOS 9845 chip or higher, will be compatible and give you spare IO for later)
Time to create page: 0.044 seconds
