Weird error - simulation on Fedora 20 / 64 bits
20 Jun 2014 04:20 #48133 by itai
I'm using 2.6.0-pre. Simulation only. Configured with "--prefix=/usr/local/linuxcnc --enable-simulator".
Everything works OK after installation, however, after not in use for some time I try to use linuxcnc and I get:
$ /usr/local/linuxcnc/bin/linuxcnc
LINUXCNC - 2.6.0~pre
Error in startup script: couldn't load file "/usr/local/linuxcnc/lib/tcltk/linuxcnc/bin/../linuxcnc.so": liblinuxcncini.so.0: cannot open shared object file: No such file or directory
    while executing
"load [file join [file dirname [info script]] linuxcnc[info sharedlibextension]]"
    (file "/usr/local/linuxcnc/lib/tcltk/linuxcnc/bin/../linuxcnc.tcl" line 59)
    invoked from within
"source [file join [file dirname [info script]] .. linuxcnc.tcl]"
    (file "/usr/local/linuxcnc/lib/tcltk/linuxcnc/bin/pickconfig.tcl" line 29)
To resolve the problem (until it happens again) I only cd to the src directory and run "make install".
Everything is already compiled, so it should only copy the files to the install directory.
I did not find anything that has changed by this operation.
After "make install" everythign is OK for maybe a week.
Any hint on what could be wrong?
Thanks,
-- Itai
20 Jun 2014 13:25 - 22 Jun 2014 21:25 #48139 by ArcEye
The prefix should be /usr/local or better still /usr
The install needs to find /bin /share /lib /include etc as sub dirs of the prefix you specify, and they should be in the PATH and LD_LIBDIR environment variables etc. so the only two that make sense are /usr and /usr/local
If you want it in one place and do not want files in your file system, then build as a RunInPlace build (ie no prefix)
Last edit: 22 Jun 2014 21:25 by ArcEye.
26 Jun 2014 05:32 #48247 by itai
Thanks!
Adding the library path to ld.conf probably fixed my problem.
More specific, I have created a file named /etc/ld.so.conf.d/linuxcnc.conf, with the content
And then ran the command
sudo ldconfig -v
-- Itai
26 Jun 2014 22:57 #48259 by ArcEye
sudo ldconfig -v
That is a very technically correct way to sort out a non standard library dir location B)
Glad it is sorted
