Upgrade 2.5.0 to 2.5.4
21 Jun 2014 23:17 #48168 by kayej
Upgrade 2.5.0 to 2.5.4 was created by kayej
Can I upgrade from 2.5.0 to 2.5.4?? If so how?
21 Jun 2014 23:36 #48169 by ArcEye
Replied by ArcEye on topic Upgrade 2.5.0 to 2.5.4
Entirely depends how you got to 2.5.0
If you installed from a Live CD image, so used synaptic, it could be as simple as
sudo apt-get update
sudo apt-get install linuxcnc
which will refresh the package lists and see that a newer version of linuxcnc is available and install it.
If you installed 2.5.0 some other way, you will have to specify
The following user(s) said Thank You: kayej
22 Jun 2014 02:19 #48171 by kayej
Replied by kayej on topic Upgrade 2.5.0 to 2.5.4
Worked like a charm. Thanks. Jack :)
Time to create page: 0.062 seconds
